Starting with radiance
Hi Radiance Community!
As I’m pretty-much new with this thing, I have few questions about setting up the environment for radiance, and tools I’ve seen in tutorials.
  1. It seems that is the best to run Radiance under the Unix-like OS. Is there any suggestion which distro to choose?
  2. I’ve found some tutorials by Axel Jacobs and few others as well, but I’m struggling with some parts. Some tools used in tutorials I don’t have or I’m missing something. Those are objline, objpict, etc. Also, piping to x11meta doesn’t work, as I’m missing x11meta.
Probably there will be more questions, but that’s all for now :slight_smile:
Pavle
Hi Pavle,
  1. Yes, Radiance run best under UNIX (which would include MacOS). If you’re on a Windows box, look into WSL (Windows subsystem for LINUX). There has been a thread or two recently on this mailing list. Ubuntu seems to be a good choice. I’d recommend an LTS (long-term support) release. These come out every 2 years. The most recent one is 20.04
  2. Correct. x11meta doesn’t work under Windows. Try piping objline, objpict into psmeta. This produces EPS (encapsulated postscript) files, which you should be able to open with Adobe Illustrator or Inkscape.
Hope this helps.
Hi Axel :slight_smile:
Yes, I was running it under the latest ubuntu LTS, focal, but have had issues with those tools as well. This x11meta is part of radiance?
What’s the best, to download the source and run install script or to download .tar.gz prepared for e.g. Linux?
Yes, x11meta is part of Radiance. Do you have it in your install directory?
Type ‘which oconv’ to find out where your Radiance binaries are installed. In this folder, you should also have x11meta
If you are on WSL, you also have to install an X11 server. I have not tried this myself, so can’t help you with this. Otherwise, you can only use command-line tools, but can’t run ximage, objview, rvu, x11meta, trad
See Mattia’s post from Sep 9th:
This should help
Thank you, I’ve managed to set it up.
It’s worth mentioning this post from Mattia Bressanelli
Regarding X Window server, there is a fix if you’re getting “cannot open display” error:
StackOverflow
It seems that everything ok, but when I try to follow this:
objline objects/things.rad | x11meta
I’m getting just a white screen:
After resizing the screen, in wsl i’ve got following error: fatal - cannot open file “/usr/local/lib/meta/vchars.mta”, mode “r”
It seems that “precompiled” version have some issues with x11meta, I’ll try to download source and install it using install script.
EDIT:
I’m getting the same error after installing from source…
i am really sorry, Pavlek. Cannot help you with this. My company is currently rolling Win10, but i’m still on Win7, so can’t advise on this… It does look like some kind of RAYPATH issue to me
On Win7 this x11meta thing is working?
We’re looking into it. Must be some build issue related to the library path for the metafile graphics, which predate even Radiance. Meanwhile, you could try creating a soft link from /usr/local/lib/meta to /usr/local/lib/ray/meta (assuming that’s where the files live) to see if that fixes it.
It seems that’s something with permissions :slight_smile:
I’ve created this meta dir, and also created this vchars.mta file, both with 777. Now, when I start objline chair.rad | x11meta it fires up empty x11meta, but when I resize it there is a chair :slight_smile:
It works now.
Thank you all
Hi @pavlek86,
I am looking into this X11meta issue, did you manage it by using the pre-compiled Radiance from LBNL or you build the source by yourself?
Hi @Axel_Jacobs2
Could you please help me to understand this better?
Do you mean we can’t also compile x11meta in the command-line only environment without x11 server?
Hi @Greg_Ward,
I just checked the build logs for x11meta on Mac and Ubuntu, it exists in output build/bin, and I don’t see any compiling error. Would it be possible to add a unit test for this case, so that we can expose and capture it in CI/CD?
It seems to be an issue with installing the auxiliary files, not the compilation itself. The vchars.mta and a number of other files are supposed to get copied to a location that is either identical to the default MDIR macro in meta.h, or an environment variable of the same name. I don’t know how this is done on Windows, and having a test case wouldn’t help because it’s a target configuration issue.
Ok, if it is installing issue, it makes more sense, because the current installer for mac doesn’t do anything except unzipping the compiled files to target directory, and there is no installer built for linux, currently it is just a zip file includes everything. For Windows, we actually has an installer, it has additional scripts to set up the environment variables for Radiance path.
If we need to install the auxiliary files to somewhere else other than the Radiance folder, and we might need to redesign the installers for each system. @Rob_Guglielmetti do you have any suggestions on this?
I don’t exactly know how to help with the cmake build system, but Rmakefile has compile lines like:
cc -DMDIR=\“/usr/local/lib/ray/meta/\” -O2 -DBSD -DNOSTEREO -Dfreebsd -I/usr/X11R6/include -L/usr/X11R6/lib -I…/common -L…/lib -o bgraph bgraph.o mgvars.o mgraph.o
-lmeta -lrtrad -lm
and does the following operations at the end:
cp symbols.met vchars.met boxw.plt curve.plt line.plt scatter.plt cartesian.plt function.plt polar.plt standard.plt /usr/local/lib/ray/meta
./cv symbols.met > /usr/local/lib/ray/meta/symbols.mta
./cv vchars.met > /usr/local/lib/ray/meta/vchars.mta
As you can see, the compiled-in setting for the MDIR macro is “/usr/local/lib/ray/meta/” in this case. If you want to install these files in the standard Radiance auxiliary file location rather than a subdirectory, you can do so, but you’ll want to redefine the MDIR macro in that case to point to this, instead. Alternatively, you can set the MDIR environment variable to wherever you put these files. Note that unlike RAYPATH, you can only specify one directory, and there has to be a trailing “/” character at the end.
I don’t know how any of this happens with cmake, unfortunately. Still hoping to hear from @Rob_Guglielmetti on that…
I’m so sorry for the radio silence, I’ve been busy and distracted. I do recall resolving this locally on a per-case basis (with MDIR) and never sorted it within the cmake framework. @Mingbo, there must be a way(s) to make post-installation mods to the environment on the Mac installers, no? I’ll hit you guys up offline.
Hello! Last year I installed Linux Mint LMDE 4 on my computer. LMDE 4 is a Debian (not Ubuntu) based Mint OS. I am definitely not a Debian power user or an OS expert. Anyway, I am trying now to install Radiance on my machine. I downloaded the rad5R2all.tar.gz file from the Radiance website and extracted it to my Home directory. Then I opened the readme.txt file, in which I found the following instructions:
Blockquote “We have attempted to make it easy for you (and for us) to install the software on differently configured systems using a global make script. To install the software, just type: ./makeall install You can clean up the .o files and so forth with: ./makeall clean Or, if you are confident you can do both at the same time with: ./makeall install clean”
So I opened a terminal window and changed my directory to the “ray” directory, and then I typed “./makeall install”. Unfortunately, nothing happened. What did I do wrong, or what steps am I missing? Or is the installation process completely different for a Debian or LMDE 4 system? Thanks much!
Hi!
Did nothing happen as in Nothing Nothing? Not even an “unknown command
./makeall”
or something? That would be strange to me.
Is there a *./makeall *file in the directory you are at?
Yes, let us know what message appears, if any. Make sure you have installed the sometimes optional C-shell. Try running from the command this way:
/bin/csh -f makeall
to see if that makes any difference.
Hello Mr. Molina,
I got an error message stating that I can only put one embedded item in a
post, so I’ll try again. My apologies for any inconvenience. Thanks very
much for getting back to me. I just now tried again both the ./makeall
install command and the /bin/csh -f makeall command which Greg Ward
suggested yesterday. I have attached a screenshot to show what happened
after trying the./makeall install command. I will send a second message to
show what happened after trying the /bin/csh -f makeall command. It still
doesn’t appear that the makeall command actually installed Radiance.
Clarence Thompson, P.E.
Kalos Ergon Engineering LLC https://kalosergon.org/
1259 Lloyd Center, Suite 106
Portland, OR 97232
503 922-9148
And here’s the screenshot showing what happened after the /bin/csh -f
makeall command.
Portland, OR 97232
503 922-9148
