OpenStudio on OSX 10.8
this is my first mailing to this list. Sorry for my bad English, I am located in Austria.
I try to setup Open Studio with the radiance functionality on my Macbook. After a series of trials with no success I start a new attempt and try to follow the available instructions as close as possible.
I just did a fresh installation of OSX 10.8 on a separate partition.
1. question: This is a German OSX version, could that lead to any problems?
2. question: OSX 10.8 comes with Ruby 1.8.7. The "Radiance_Installation_Instructions_0_9_0.pdf" says "Install RUBY 1.8.6" so ist 1.8.6 required?
If yes, are there any hints how to downgrade to Ruby 1.8.6?
3. question: The installation sequence according to "Radiance_Installation_Instructions_0_9_0.pdf" seems to be reverse to the sequence described in the "Installation Instructions" on the Open Studio Webpage. The notes for OS X on that webpage also tell that Ruby 1.8.6 or 1.8.7 is supported, which comes back to question number 2.
4. question: "Radiance_Installation_Instructions_0_9_0.pdf" tells to do a separate Perl installation (ActivePerl is recommended). Is this true also for OSX?
Many thanks for any help on my way.
Best regards
Martin Klingler
Hi Martin (your English is just fine),
1. I'm fairly certain we have some German/Austrian OpenStudio users...
2. Ruby 1.8.7 works just fine with OpenStudio -- in fact, yours is the same setup as I have (OSX10.8 + Ruby 1.8.7)
3. The install doc you are working off of is outdated (see #4).
4. The Perl install directive is only for people running OpenStudio on Windows; OSX and Linux users most likely already have Perl installed (as well as Ruby).
What version of OpenStudio are you trying to install? I highly recommend installing the latest iteration version, which is 0.9.3. That installer can be downloaded from the Developers tab on the OpenStudio website:
http://openstudio.nrel.gov/developers
Direct link to Mac installer:
http://openstudio.nrel.gov/accept/file/1162
Once you have that version installed, let us know how you make out. If you still have problems, please post some specifics about the nature of the problem.
Sent: Tuesday, October 30, 2012 3:56 AM
Subject: [Radiance-openstudio] OpenStudio on OSX 10.8
Best regards
Martin Klingler
Hi Rob,
thank you very much for your instructions. I just did the complete installation (EnergyPlus 7.1, Sketchup 8, Radiance 4.2.a and Openstudio 0.9.3).
I then followed very closely your tutorial about OpenStudio New Features - Radiance Integration. But the run failed (see https://dl.dropbox.com/u/27495200/Pic2.png).
Just in case, I have uploaded also my example file (https://dl.dropbox.com/u/27495200/office2.zip).
In Sketchup, when closing the preference window there is a warning about the path to EnergyPlus(https://dl.dropbox.com/u/27495200/Pic1.png). But the tools seem to be recognized (https://dl.dropbox.com/u/27495200/Pic3.png).
Any idea what is going wrong?
Thanks and best regards
Martin Klingler
Original Message
processed by CONSOLIDATE
Subject:
RE: [Radiance-openstudio] OpenStudio on OSX 10.8
Sent:
Dienstag, 30. Oktober 2012 16:07
Guglielmetti, Robert ([email protected])
1. Im fairly certain we have some German/Austrian OpenStudio users...
Best regards
Martin Klingler
Hi Martin,
The first thing I would do is to re-run "scan for tools" in the OS app (under the File… menu). Make sure EnergyPlus 7.1 is there, and then remove as a tool any other versions of EnergyPlus that may show up. Generally those shouldn’t matter, but we have seen cases where having an old version prevented the simulation from running.
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 10/31/12 11:29 AM, "Martin Klingler" <[email protected]<mailto:[email protected]>> wrote:
Hi Rob,
Martin Klingler
Original Message
processed by CONSOLIDATE <http://www.consolidate.at>
Subject:
Sent:
Guglielmetti, Robert ([email protected]<mailto:[email protected]>)
1. I’m fairly certain we have some German/Austrian OpenStudio users...
From: Martin Klingler [[email protected]<mailto:[email protected]>]
To: [email protected]<mailto:[email protected]>
Best regards
Martin Klingler
Hi Rob,
thank´s for your advice.
The re-run of "scan for tools" only shows the one EnergyPlus 7.1 installation plus radiance and ruby . There is no other version of anything, this is a complete fresh installation (see my first mail in this thread).
Some more infos to the error:
---------------- File stdout:
Setting RAYPATH: /usr/local/radiance/lib /usr/local/radiance/bin
Appending PATH: /usr/local/radiance/bin
?ruby -I ?/Library/Ruby/Site/1.8? -I ?/Library/Ruby/Site/1.8/powerpc-darwin12.0? -I ?/Library/Ruby/Site/1.8/universal-darwin12.0? -I ?/Library/Ruby/Site? -I ?/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/vendor_ruby/1.8? -I ?/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/vendor_ruby/1.8/universal-darwin12.0? -I ?/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/vendor_ruby? -I ?/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8? -I ?/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/powerpc-darwin12.0? -I ?/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/universal-darwin12.0? -I ?.? -I ?/Library/Ruby/Site/? -I ?/Library/Ruby/Site/openstudio? -I ?/Library/Ruby/Site/lib? ?./ModelToRad.rb? /private/var/folders/30/8y6hrx_12fs91f5ls6rs38dw0000gn/T/qt_temp.biC335/resources/run/0-Ruby/in.osm ?
no sql file given, running EnergyPlus...
Looking for EnergyPlus at /Applications/EnergyPlus-7-1-0
Found EnergyPlus.
failed to run ModelToRad
---------------- End file stdout
---------------- File stderr:
./ModelToRad.rb:166:in `create?: Unable to locate file in search paths (RuntimeError)
from ./ModelToRad.rb:166
---------------- End file stderr
Any idea what is wrong or missing?
Thank you very much
Martin
Original Message
Subject:
Re: [Radiance-openstudio] OpenStudio on OSX 10.8
Sent:
Mittwoch, 31. Oktober 2012 20:36
Hi Martin,
The first thing I would do is to re-run "scan for tools" in the OS app (under the File menu). Make sure EnergyPlus 7.1 is there, and then remove as a tool any other versions of EnergyPlus that may show up. Generally those shouldnt matter, but we have seen cases where having an old version prevented the simulation from running.
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 10/31/12 11:29 AM, "Martin Klingler" > wrote:
Hi Rob,
Martin Klingler
Original Message
Subject:
Sent:
Best regards
Martin Klingler
Hi, Martin
I’m facing the same problem. I did try to do the simulation through
simulation, however I did not succeed.
I just want to know whether you manage to solve the problem or not.
Thanks
Khalid
Sent: Sunday, November 04, 2012 12:06 PM
Subject: Re: [Radiance-openstudio] OpenStudio on OSX 10.8
Hi Rob,
’ruby -I ’/Library/Ruby/Site/1.8’ -I
’/Library/Ruby/Site/1.8/powerpc-darwin12.0’ -I
’/Library/Ruby/Site/1.8/universal-darwin12.0’ -I ’/Library/Ruby/Site’ -I
’/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/vendor_
ruby/1.8’ -I
ruby/1.8/universal-darwin12.0’ -I
ruby’ -I
’/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8’ -I
’/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/pow
erpc-darwin12.0’ -I
’/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/uni
versal-darwin12.0’ -I ’.’ -I ’/Library/Ruby/Site/’ -I
’/Library/Ruby/Site/openstudio’ -I ’/Library/Ruby/Site/lib’
’./ModelToRad.rb’
urces/run/0-Ruby/in.osm ’
Found EnergyPlus.
./ModelToRad.rb:166:in `create’: Unable to locate file in search paths
(RuntimeError)
Thank you very much
Martin
Original Message
processed by <http://www.consolidate.at> CONSOLIDATE
Subject:
Sent:
Guglielmetti, Robert ( <mailto:[email protected]>
[email protected])
Hi Martin,
(under the File
Rob Guglielmetti
Golden, CO 80401
303.275.4319
Hi Rob,
0.9.3).
Martin Klingler
Original Message
Subject:
Sent:
well as Ruby).
problem.
located in Austria.
ist 1.8.6 required?
for OSX?
Best regards
Martin Klingler
  _____
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2013.0.2742 / Virus Database: 2617/5873 - Release Date: 11/04/12
Hi Khalid,
Can you tell me more about your setup? OpenStudio version, EnergyPlus version, how is Radiance installed, and what error(s) you are experiencing?
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 11/7/12 5:51 AM, "Khalid" <[email protected]<mailto:[email protected]>> wrote:
Hi, Martin
I’m facing the same problem. I did try to do the simulation through simulation, however I did not succeed.
Thanks
Khalid
Hi Rob,
’ruby -I ’/Library/Ruby/Site/1.8’ -I ’/Library/Ruby/Site/1.8/powerpc-darwin12.0’ -I ’/Library/Ruby/Site/1.8/universal-darwin12.0’ -I ’/Library/Ruby/Site’ -I ’/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/vendor_ruby/1.8’ -I ’/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/vendor_ruby/1.8/universal-darwin12.0’ -I ’/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/vendor_ruby’ -I ’/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8’ -I ’/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/powerpc-darwin12.0’ -I ’/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/universal-darwin12.0’ -I ’.’ -I ’/Library/Ruby/Site/’ -I ’/Library/Ruby/Site/openstudio’ -I ’/Library/Ruby/Site/lib’ ’./ModelToRad.rb’ /private/var/folders/30/8y6hrx_12fs91f5ls6rs38dw0000gn/T/qt_temp.biC335/resources/run/0-Ruby/in.osm ’
Found EnergyPlus.
./ModelToRad.rb:166:in `create’: Unable to locate file in search paths (RuntimeError)
Thank you very much
Martin
Original Message
Subject:
Sent:
Hi Martin,
Rob Guglielmetti
Golden, CO 80401
303.275.4319
Hi Rob,
Martin Klingler
Original Message
Subject:
Sent:
Best regards
Martin Klingler
Checked by AVG - www.avg.com<http://www.avg.com>
Hi Rob,
I'm using OpenStudio 0.9.3, EnergyPlus 7.1.0
Radiance is installed in c drive;
https://docs.google.com/open?id=0ByEvb-Y7hX3xQlNZbl9LWE1YeFE
The error I'm receiving is just that the simulation has failed:
https://docs.google.com/open?id=0ByEvb-Y7hX3xUzdjUkZwNFdab1U
Actually I did follow the steps as shown in Martin message.
Thanks
Khalid
Sent: Wednesday, November 07, 2012 9:58 PM
To: Discussion of Radiance with OpenStudio
Hi Khalid,
Rob Guglielmetti
National Renewable Energy Laboratory (NREL) Commercial Buildings Research
Group
Golden, CO 80401
303.275.4319
Hi, Martin
Thanks
Khalid
To:
[email protected]<mailto:radiance-openstudio@radiance-
online.org>
Hi Rob,
ruby/1.8’ -I
ruby’ -I
erpc-darwin12.0’ -I
’./ModelToRad.rb’
Found EnergyPlus.
(RuntimeError)
Thank you very much
Martin
Original Message
Subject:
Sent:
Hi Martin,
(under the File
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Hi Rob,
0.9.3).
Martin Klingler
Original Message
Subject:
Sent:
setup as I have (OSX10.8 + Ruby 1.8.7) 3. The install doc you are working
well as Ruby).
problem.
To:
online.org>
located in Austria.
ist 1.8.6 required?
for OSX?
Best regards
Martin Klingler
Radiance-openstudio mailing list
http://www.radiance-online.org/mailman/listinfo/radiance-openstudio
Version: 2013.0.2742 / Virus Database: 2617/5877 - Release Date: 11/06/12
Hi Khalod, hi Rob,
had to do some work away from home, so it took some time.
I had no success on the OSX platform. Also 0.9.4 doesn´t change anything.
The run stops very fast with the following messages in stdout:
?ruby -I ?/Library/Ruby/Site/1.8? -I ?/Library/Ruby/Site/1.8/powerpc-darwin12.0? -I ?/Library/Ruby/Site/1.8/universal-darwin12.0? -I ?/Library/Ruby/Site? -I ?/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/vendor_ruby/1.8? -I ?/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/vendor_ruby/1.8/universal-darwin12.0? -I ?/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/vendor_ruby? -I ?/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8? -I ?/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/powerpc-darwin12.0? -I ?/System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/universal-darwin12.0? -I ?.? -I ?/Library/Ruby/Site/? -I ?/Library/Ruby/Site/openstudio? -I ?/Library/Ruby/Site/lib? ?./ModelToRad.rb? ?/private/var/folders/30/8y6hrx_12fs91f5ls6rs38dw0000gn/T/qt_temp.JpW419/resources/run/0-Ruby/in.osm? ???
Found EnergyPlus.
Stderr tells the following:
On the other hand I had success with Windows 7. No problems with installation and run radiance within OpenStudio (I will go on testing with the command line tools).
As my final target will be OSX, I still appreciate any idea concerning my problem.
Many thanks and best regards
Martin
Original Message
Subject:
Sent:
Mittwoch, 07. November 2012 13:52
Khalid ([email protected])
Hi, Martin
Im facing the same problem. I did try to do the simulation through simulation, however I did not succeed.
Thanks
Khalid
Hi Rob,
ruby -I /Library/Ruby/Site/1.8 -I /Library/Ruby/Site/1.8/powerpc-darwin12.0 -I /Library/Ruby/Site/1.8/universal-darwin12.0 -I /Library/Ruby/Site -I /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/vendor_ruby/1.8 -I /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/vendor_ruby/1.8/universal-darwin12.0 -I /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/vendor_ruby -I /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8 -I /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/powerpc-darwin12.0 -I /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/universal-darwin12.0 -I . -I /Library/Ruby/Site/ -I /Library/Ruby/Site/openstudio -I /Library/Ruby/Site/lib ./ModelToRad.rb /private/var/folders/30/8y6hrx_12fs91f5ls6rs38dw0000gn/T/qt_temp.biC335/resources/run/0-Ruby/in.osm
Found EnergyPlus.
./ModelToRad.rb:166:in `create: Unable to locate file in search paths (RuntimeError)
Thank you very much
Martin
Original Message
Subject:
Sent:
Hi Martin,
Rob Guglielmetti
Golden, CO 80401
303.275.4319
Hi Rob,
Martin Klingler
Original Message
Subject:
Sent:
Best regards
Martin Klingler
Thanks Martin
I did use Openstudio 0.9.4 . then it seem that radiance has start to work.
However, it does not stop
And keep running as shown in this link:
I do appreciate if anybody can help in such problem
Thanks
I'm not sure about OpenStudio specifically, but it looks like you're running an annual simulation. The last line seems to represent timestep 1 (January) 8 at 11:00:00 AM. Wouldn't you expect it to keep going until it gets to 12 31 23:00:00 for December 31?
Sent: Tuesday, November 13, 2012 7:55 AM
To: 'Discussion of Radiance with OpenStudio'
Thanks Martin
I did use Openstudio 0.9.4 ... then it seem that radiance has start to work. However, it does not stop
Thanks
Thanks Chris! Yes, Khalid, the text output seems to indicate that the annual simulation is running; does it not continue on through to December?
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 11/13/12 6:52 AM, "Christopher Rush" <[email protected]<mailto:[email protected]>> wrote:
I’m not sure about OpenStudio specifically, but it looks like you’re running an annual simulation. The last line seems to represent timestep 1 (January) 8 at 11:00:00 AM. Wouldn’t you expect it to keep going until it gets to 12 31 23:00:00 for December 31?
Thanks Martin
I did use Openstudio 0.9.4 … then it seem that radiance has start to work. However, it does not stop
Thanks
Thanks
The simulation does not stop. It continue running after reaching 31
December.
Sent: Tuesday, November 13, 2012 7:36 PM
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Thanks Martin
However, it does not stop And keep running as shown in this link:
Thanks
Electronic mail messages entering and leaving Arup business systems are
Version: 2013.0.2793 / Virus Database: 2624/5890 - Release Date: 11/12/12
OK, that's a good thing. How many spaces and illuminance maps do you have
in the model? Currently the program computes each map serially, i.e. one
at a time, so you'll have to wait for it to finish all the maps before
it's fully done. After that, it will do a dimming analysis and create a
lighting load schedule for EnergyPlus, which is then automatically run as
well. It can take some time on a large model with lots of spaces. But it
does sound like things are working for you. When it's all done you should
see a "finished" message and hopefully zero errors (there are usually
warnings even on successful runs), and then you can open the eplusout.sql
file in ResultsViewer to review the daylighting.
Keep us posted!
P.S. We are rewriting the daylighting script to compute all the points in
the model at one time, rather than space-by-space; this speeds up the
calculation times on large models significantly, and should be available
in the next iteration release which is due out early next week.
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 11/13/12 9:55 AM, "Khalid" <[email protected]> wrote:
Thanks
December.
annual
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
On 11/13/12 6:52 AM, "Christopher Rush" ><[email protected]<mailto:[email protected]>> wrote:
running
(January)
Thanks Martin
Dropbox - Error - Simplify your life
Thanks
Thanks Rob,
I Have one space and one illuminance map
Sent: Tuesday, November 13, 2012 8:08 PM
OK, that's a good thing. How many spaces and illuminance maps do you have in
the model? Currently the program computes each map serially, i.e. one at a
time, so you'll have to wait for it to finish all the maps before it's fully
done. After that, it will do a dimming analysis and create a lighting load
schedule for EnergyPlus, which is then automatically run as well. It can
take some time on a large model with lots of spaces. But it does sound like
things are working for you. When it's all done you should see a "finished"
message and hopefully zero errors (there are usually warnings even on
successful runs), and then you can open the eplusout.sql file in
Keep us posted!
calculation times on large models significantly, and should be available in
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Thanks
December.
December?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
1
(January)
12
Thanks Martin
Thanks
11/12/12
Ok, then after the annual daylighting sim, you should have seen some
messages about the lighting, and then the glare analysis, and finally the
EnergyPlus messages.
I'm happy to work with you offline on this, if you want to send me any
results or screenshots directly (I assume you've noticed that the list
server rejects posts with attachments?).
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 11/13/12 10:15 AM, "Khalid" <[email protected]> wrote:
Thanks Rob,
in
fully
like
Keep us posted!
in
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Thanks
December.
December?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
On 11/13/12 6:52 AM, "Christopher Rush" >><[email protected]<mailto:[email protected]>> wrote:
1
(January)
12
Thanks Martin
work.
Thanks
11/12/12
I did not see any results, the simulation did not stop. I did made a change
on the weather file and reduce it to day days, to see whether it will stop
or not.
I will send you any result that I will get.
Thanks again
Sent: Tuesday, November 13, 2012 8:32 PM
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Thanks Rob,
have in the model? Currently the program computes each map serially,
i.e. one at a time, so you'll have to wait for it to finish all the
maps before it's fully done. After that, it will do a dimming analysis
and create a lighting load schedule for EnergyPlus, which is then
automatically run as well. It can take some time on a large model with
lots of spaces. But it does sound like things are working for you. When
Keep us posted!
in the model at one time, rather than space-by-space; this speeds up
the calculation times on large models significantly, and should be
available in the next iteration release which is due out early next
week.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks
December.
December?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
timestep
1
(January)
to
12
Thanks Martin
work.
Thanks
11/12/12
11/12/12
The OpenStudio app does not support sub-annual runperiods (yet), so that
will likely not work for you. When you say the sim does not stop, is it
still printing messages to the console window, i.e. still "doing stuff"?
Rob Guglielmetti
Golden, CO 80401
303.275.4319
change
or not.
Thanks again
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Thanks Rob,
Keep us posted!
week.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks
December.
December?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
On 11/13/12 6:52 AM, "Christopher Rush" >>><[email protected]<mailto:[email protected]>> wrote:
timestep
1
(January)
to
12
Thanks Martin
work.
Thanks
11/12/12
11/12/12
Yes, it continue printing:
Radiance (rcontrib) calculating: 1 2 09:00:00
Radiance (rcontrib) calculating: 1 2 10:00:00
Radiance (rcontrib) calculating: 1 2 11:00:00
and continue for the new hour
Sent: Tuesday, November 13, 2012 8:59 PM
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
change on the weather file and reduce it to day days, to see whether it
will stop or not.
Thanks again
the EnergyPlus messages.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks Rob,
Keep us posted!
week.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks
December.
December?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
timestep
1
(January)
to
12
Thanks Martin
work.
Thanks
11/12/12
11/12/12
11/12/12
OK, sounds like it's working. It should go through every hour of the year,
and then it will perform the other calculations and let you know when it's
finished.
Rob Guglielmetti
Golden, CO 80401
303.275.4319
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
will stop or not.
Thanks again
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks Rob,
Keep us posted!
week.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks
December.
December?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
On 11/13/12 6:52 AM, "Christopher Rush" >>>><[email protected]<mailto:[email protected]>> wrote:
timestep
1
(January)
to
12
Thanks Martin
work.
Thanks
11/12/12
11/12/12
11/12/12
