OpenStudio on OSX 10.8
Thanks Rob
I did edit the weather file, I made it just for one day, first day in
January;
https://www.dropbox.com/s/iqxjj5u1pls21pv/USA_FL_Tampa.Intl.AP.722110_TMY3.e
pw?m
However the simulation took about two hours. I was surprised to see in the
simulation process that the simulation done for days
In October and November and December:
The output file:
https://www.dropbox.com/s/r6t086gca4soasu/out1.txt?m
The following files will show the results;
Illuminance map`:
Illuminance map2:
Error:
https://www.dropbox.com/s/0vu1t33emw2zzb5/Err.txt?m
Glare:
Global horizontal illuminance
Dropbox - Error - Simplify your life.
jpg?m
When I did the simulation using radiance, I will get the simulation has
failed.
However, when I just run openstudio without radiance, the run will complete
without any problem:
https://www.dropbox.com/s/ejrphiqbmogpk2l/EPLUSout.txt?m
Sent: Tuesday, November 13, 2012 10:50 PM
To: Discussion of Radiance with OpenStudio
Subject: Re: [Radiance-openstudio] OpenStudio on OSX 10.8
OK, sounds like it's working. It should go through every hour of the year,
and then it will perform the other calculations and let you know when it's
finished.
Rob Guglielmetti
National Renewable Energy Laboratory (NREL) Commercial Buildings Research
Group
Golden, CO 80401
303.275.4319
On 11/13/12 11:10 AM, "Khalid" <[email protected]> wrote:
Yes, it continue printing:
Radiance (rcontrib) calculating: 1 2 09:00:00 Radiance (rcontrib)
calculating: 1 2 10:00:00 Radiance (rcontrib) calculating: 1 2 11:00:00
and continue for the new hour
Sent: Tuesday, November 13, 2012 8:59 PM
The OpenStudio app does not support sub-annual runperiods (yet), so
that will likely not work for you. When you say the sim does not stop,
is it still printing messages to the console window, i.e. still "doing
stuff"?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
On 11/13/12 10:48 AM, "Khalid" <[email protected]> wrote:
I did not see any results, the simulation did not stop. I did made a
change on the weather file and reduce it to day days, to see whether
it will stop or not.
I will send you any result that I will get.
Thanks again
Sent: Tuesday, November 13, 2012 8:32 PM
Ok, then after the annual daylighting sim, you should have seen some
messages about the lighting, and then the glare analysis, and finally
the EnergyPlus messages.
I'm happy to work with you offline on this, if you want to send me any
results or screenshots directly (I assume you've noticed that the list
server rejects posts with attachments?).
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
On 11/13/12 10:15 AM, "Khalid" <[email protected]> wrote:
Thanks Rob,
I Have one space and one illuminance map
Sent: Tuesday, November 13, 2012 8:08 PM
OK, that's a good thing. How many spaces and illuminance maps do you
have in the model? Currently the program computes each map serially,
i.e. one at a time, so you'll have to wait for it to finish all the
maps before it's fully done. After that, it will do a dimming
analysis and create a lighting load schedule for EnergyPlus, which is
then automatically run as well. It can take some time on a large
model with lots of spaces. But it does sound like things are working for
you.
When it's all done you should see a "finished"
message and hopefully zero errors (there are usually warnings even on
successful runs), and then you can open the eplusout.sql file in
ResultsViewer to review the daylighting.
Keep us posted!
P.S. We are rewriting the daylighting script to compute all the
points in the model at one time, rather than space-by-space; this
speeds up the calculation times on large models significantly, and
should be available in the next iteration release which is due out
early next week.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
On 11/13/12 9:55 AM, "Khalid" <[email protected]> wrote:
Thanks
The simulation does not stop. It continue running after reaching 31
December.
Sent: Tuesday, November 13, 2012 7:36 PM
Thanks Chris! Yes, Khalid, the text output seems to indicate that
the annual simulation is running; does it not continue on through to
December?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
On 11/13/12 6:52 AM, "Christopher Rush" >>>><[email protected]<mailto:[email protected]>> wrote:
I'm not sure about OpenStudio specifically, but it looks like you're
running an annual simulation. The last line seems to represent
timestep
1
(January)
8 at 11:00:00 AM. Wouldn't you expect it to keep going until it gets
to
12
31 23:00:00 for December 31?
Sent: Tuesday, November 13, 2012 7:55 AM
To: 'Discussion of Radiance with OpenStudio'
Thanks Martin
I did use Openstudio 0.9.4 . then it seem that radiance has start to
work.
However, it does not stop And keep running as shown in this link:
I do appreciate if anybody can help in such problem
Thanks
Electronic mail messages entering and leaving Arup business systems
are scanned for acceptability of content and viruses
Radiance-openstudio mailing list
http://www.radiance-online.org/mailman/listinfo/radiance-openstudio
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2013.0.2793 / Virus Database: 2624/5890 - Release Date:
11/12/12
11/12/12
11/12/12
11/12/12
Version: 2013.0.2793 / Virus Database: 2629/5892 - Release Date: 11/13/12
Hi Khalid,
Thanks for all this extra detail! OK, first of all, editing the weather
file to do shorter run periods is not recommended. As you saw, this has no
effect on the Radiance piece (this is because OpenStudio pulls the weather
info from an EnergyPlus pre-process run, which is for an annual
runperiod). Support for shorter runperiods is being put into the app
currently, but I'm not sure when that will be released. Editing the
weather file like you did also caused the "..... Last severe
error=ProcessScheduleInput: Schedule:Compact="THERMAL ZONE 1 LIGHTS
SCHEDULE" has missing days in its schedule pointers" error.
The illuminance map data is goofy; are you looking at data from
radout.sql, or eplusout.sql?
It appears that your simulation is running OK; on a slower system (and
especially on Windows) a two hour run time for an annual sim is not
unusual. I'd try re-running the sim with the full weather file, let it run
its course, and re-review the data. You can also send me your model and
weather file and I can make sure everything looks good.
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 11/13/12 9:32 PM, "Khalid" <[email protected]> wrote:
Thanks Rob
January;
.e
pw?m
The output file:
Illuminance map`:
Illuminance map2:
Error:
Glare:
e.
jpg?m
failed.
complete
finished.
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
stuff"?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks again
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks Rob,
for
you.
Keep us posted!
early next week.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks
December.
December?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
On 11/13/12 6:52 AM, "Christopher Rush" >>>>><[email protected]<mailto:[email protected]>> wrote:
timestep
1
(January)
to
12
Thanks Martin
work.
Thanks
11/12/12
11/12/12
11/12/12
11/12/12
Thanks Rob,
I did a re-run for a full weather file, and took about one hour.
I used the weather file for Tampa which come with Energyplus:
pw?m
The following results are from Radout.sql:
jpg?m
The model I used is the one in Martin message:
(https://dl.dropbox.com/u/27495200/office2.zip\).
Rob, I have a question regarding the reflectance of ground, I did not knew
how to get the reflectance of ground , and how to change such reflectance in
Openstudio.
Thanks
Sent: Wednesday, November 14, 2012 9:45 PM
Hi Khalid,
info from an EnergyPlus pre-process run, which is for an annual runperiod).
Support for shorter runperiods is being put into the app currently, but I'm
not sure when that will be released. Editing the weather file like you did
The illuminance map data is goofy; are you looking at data from radout.sql,
or eplusout.sql?
especially on Windows) a two hour run time for an annual sim is not unusual.
I'd try re-running the sim with the full weather file, let it run its
course, and re-review the data. You can also send me your model and weather
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Thanks Rob
January;
MY3
.e
pw?m
the simulation process that the simulation done for days In October and
The output file:
Illuminance map`:
Illuminance map2:
Error:
Glare:
anc
e.
jpg?m
failed.
complete without any problem:
year, and then it will perform the other calculations and let you know
when it's finished.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
11:00:00
stuff"?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks again
any results or screenshots directly (I assume you've noticed that the
list server rejects posts with attachments?).
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks Rob,
is then automatically run as well. It can take some time on a large
for
you.
on successful runs), and then you can open the eplusout.sql file in
Keep us posted!
early next week.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks
31 December.
to December?
Rob Guglielmetti
Research Group
15013 Denver West Parkway MS:RSF202 Golden, CO 80401
303.275.4319
you're running an annual simulation. The last line seems to
represent timestep
1
(January)
gets to
12
Thanks Martin
to work.
Thanks
11/12/12
11/12/12
11/12/12
11/12/12
11/13/12
Thanks Khalid,
The results that you have shared seem ok, I'll run your model here later
tonight to confirm. As far as ground reflectance, the default is 20% (this
is applied for any rays intersecting the sphere below the horizon).
However, good modeling practice dictates that you model local ground
features and obstructions, so that local shadow effects are captured. You
can do this in OpenStudio using "site shading surfaces". You first create
a site shading surface group, then draw your local ground planes inside of
that group. You can change the reflectance of those objects by adding
materials to the library that are of the reflectance you want, and
assigning them to the objects' constructions.
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 11/14/12 7:58 AM, "Khalid" <[email protected]> wrote:
Thanks Rob,
.e
pw?m
e.
jpg?m
in
Openstudio.
Thanks
Hi Khalid,
runperiod).
I'm
radout.sql,
or eplusout.sql?
unusual.
weather
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Thanks Rob
January;
MY3
.e
pw?m
The output file:
Illuminance map`:
Illuminance map2:
Error:
Glare:
anc
e.
jpg?m
failed.
when it's finished.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
11:00:00
stuff"?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks again
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks Rob,
for
you.
Keep us posted!
early next week.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks
31 December.
to December?
Rob Guglielmetti
Research Group
303.275.4319
On 11/13/12 6:52 AM, "Christopher Rush" >>>>>><[email protected]<mailto:[email protected]>> wrote:
represent timestep
1
(January)
gets to
12
Thanks Martin
to work.
Thanks
11/12/12
11/12/12
11/12/12
11/12/12
11/13/12
Thank you very much for your help, Rob.
Sent: Thursday, November 15, 2012 2:12 AM
Thanks Khalid,
can do this in OpenStudio using "site shading surfaces". You first create a
materials to the library that are of the reflectance you want, and assigning
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Thanks Rob,
MY3
.e
pw?m
anc
e.
jpg?m
knew how to get the reflectance of ground , and how to change such
reflectance in Openstudio.
Thanks
Hi Khalid,
weather file to do shorter run periods is not recommended. As you saw,
this has no effect on the Radiance piece (this is because OpenStudio
pulls the weather info from an EnergyPlus pre-process run, which is for
I'm not sure when that will be released. Editing the weather file like
unusual.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks Rob
January;
T
MY3
.e
pw?m
The output file:
Illuminance map`:
Illuminance map2:
Error:
Glare:
n
anc
e.
jpg?m
has failed.
when it's finished.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
11:00:00
stop, is it still printing messages to the console window, i.e. still
"doing
stuff"?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks again
finally the EnergyPlus messages.
the list server rejects posts with attachments?).
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks Rob,
you have in the model? Currently the program computes each map
serially, i.e. one at a time, so you'll have to wait for it to
finish all the maps before it's fully done. After that, it will do
a dimming analysis and create a lighting load schedule for
EnergyPlus, which is then automatically run as well. It can take
some time on a large model with lots of spaces. But it does sound
you.
Keep us posted!
early next week.
Rob Guglielmetti
Research Group
303.275.4319
Thanks
31 December.
to December?
Rob Guglielmetti
Research Group
303.275.4319
represent timestep
1
(January)
gets to
12
Thanks Martin
to work.
Thanks
o
11/12/12
o
11/12/12
11/12/12
11/12/12
11/13/12
11/13/12
Version: 2013.0.2793 / Virus Database: 2629/5895 - Release Date: 11/14/12
Hi Khalid,
Well one thing's for sure, we need to speed up our code on Windows
machines! I just ran your model and did the full annual simulation in 8
minutes. I have a grad student here at NREL using OpenStudio for a
greenhouse project and his OpenStudio model takes 2 hours to run on his
system, and that one ran in 10 minutes on my laptop. I suspect that all
the multithreading work that Greg has implemented is super awesome, and
that's why Linux and MacOS machines are running all the Radiance stuff a
lot faster than on Windows. We implemented multithreading on Windows using
the Ruby Threads class, but we either implemented that badly or it simply
doesn't work as well as the stuff that's built into Radiance (that does
not work on Windows).
I digress, but I thank you for exposing these things. Anyway, the data all
seems to make sense to me, are you familiar with the ResultsViewer
application for viewing your results? I know you posted some screen shots,
but are you able to zoom in on time periods and make plots? Let me know!
Rob Guglielmetti
Golden, CO 80401
303.275.4319
Thanks Khalid,
a
assigning
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Thanks Rob,
MY3
.e
pw?m
anc
e.
jpg?m
Thanks
Hi Khalid,
unusual.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks Rob
January;
T
MY3
.e
pw?m
The output file:
Illuminance map`:
Illuminance map2:
Error:
Glare:
n
anc
e.
jpg?m
has failed.
when it's finished.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
11:00:00
"doing
stuff"?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks again
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks Rob,
you.
Keep us posted!
early next week.
Rob Guglielmetti
Research Group
303.275.4319
Thanks
31 December.
to December?
Rob Guglielmetti
Research Group
303.275.4319
On 11/13/12 6:52 AM, "Christopher Rush" >>>>>>><[email protected]<mailto:[email protected]>> wrote:
represent timestep
1
(January)
gets to
12
Thanks Martin
to work.
Thanks
o
11/12/12
o
11/12/12
11/12/12
11/12/12
11/13/12
11/13/12
Hi Rob,
Well, I should try to do the simulation on Linux. I have 'ubuntu' installed
on pc, I should give a try.
Regarding the ResultViewer, I have no problem using it, thanks.
Sent: Thursday, November 15, 2012 2:37 AM
Hi Khalid,
Well one thing's for sure, we need to speed up our code on Windows machines!
I just ran your model and did the full annual simulation in 8 minutes. I
have a grad student here at NREL using OpenStudio for a greenhouse project
and his OpenStudio model takes 2 hours to run on his system, and that one
ran in 10 minutes on my laptop. I suspect that all the multithreading work
that Greg has implemented is super awesome, and that's why Linux and MacOS
machines are running all the Radiance stuff a lot faster than on Windows. We
implemented multithreading on Windows using the Ruby Threads class, but we
either implemented that badly or it simply doesn't work as well as the stuff
that's built into Radiance (that does not work on Windows).
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Thanks Khalid,
later tonight to confirm. As far as ground reflectance, the default is
20% (this is applied for any rays intersecting the sphere below the
horizon).
You can do this in OpenStudio using "site shading surfaces". You first
create a site shading surface group, then draw your local ground planes
inside of that group. You can change the reflectance of those objects
by adding materials to the library that are of the reflectance you
want, and assigning them to the objects' constructions.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks Rob,
T
MY3
.e
pw?m
n
anc
e.
jpg?m
Thanks
Hi Khalid,
but I'm not sure when that will be released. Editing the weather file
unusual.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks Rob
January;
_
T
MY3
.e
pw?m
in the simulation process that the simulation done for days In
The output file:
Illuminance map`:
Illuminance map2:
Error:
Glare:
i
n
anc
e.
jpg?m
has failed.
know when it's finished.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
11:00:00
still "doing
stuff"?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
a change on the weather file and reduce it to day days, to see
whether it will stop or not.
Thanks again
some messages about the lighting, and then the glare analysis, and
Rob Guglielmetti
Research Group
303.275.4319
Thanks Rob,
you.
in ResultsViewer to review the daylighting.
Keep us posted!
early next week.
Rob Guglielmetti
Research Group
303.275.4319
Thanks
31 December.
to December?
Rob Guglielmetti
Research Group
303.275.4319
represent timestep
1
(January)
gets to
12
Thanks Martin
to work.
Thanks
i
o
11/12/12
i
o
o
11/12/12
o
11/12/12
11/12/12
11/13/12
11/13/12
11/14/12
Hi Khalid,
THat would be great if you're willing to give it a try! I don't know that there are a lot of people trying out the Linux version. Ubuntu is what we develop and test on, too.
On Nov 14, 2012, at 8:52 AM, "Khalid" <[email protected]> wrote:
Hi Rob,
Hi Khalid,
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Thanks Khalid,
horizon).
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks Rob,
T
MY3
.e
pw?m
n
anc
e.
jpg?m
Thanks
Hi Khalid,
unusual.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks Rob
January;
_
T
MY3
.e
pw?m
The output file:
Illuminance map`:
Illuminance map2:
Error:
Glare:
i
n
anc
e.
jpg?m
has failed.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
11:00:00
still "doing
stuff"?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks again
Rob Guglielmetti
Research Group
303.275.4319
Thanks Rob,
you.
Keep us posted!
early next week.
Rob Guglielmetti
Research Group
303.275.4319
Thanks
31 December.
to December?
Rob Guglielmetti
Research Group
303.275.4319
On 11/13/12 6:52 AM, "Christopher Rush" >>>>>>>> <[email protected]<mailto:[email protected]>> wrote:
represent timestep
1
(January)
gets to
12
Thanks Martin
to work.
Thanks
i
o
11/12/12
i
o
o
11/12/12
o
11/12/12
11/12/12
11/13/12
11/13/12
11/14/12
Hi Khalid,
the screenshots you attached are from a windows run, did you give up on the OSX side?
Martin
Original Message
processed by CONSOLIDATE
Subject:
Sent:
Mittwoch, 14. November 2012 15:58
Khalid ([email protected])
Thanks Rob,
pw?m
Openstudio.
Thanks
Hi Khalid,
Support for shorter runperiods is being put into the app currently, but Im
or eplusout.sql?
Id try re-running the sim with the full weather file, let it run its
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
On 11/13/12 9:32 PM, "Khalid" wrote:
Thanks Rob
January;
MY3
.e
pw?m
The output file:
Illuminance map`:
Illuminance map2:
Error:
Glare:
anc
e.
jpg?m
failed.
OK, sounds like its working. It should go through every hour of the
when its finished.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
11:00:00
stuff"?
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
Thanks again
Im happy to work with you offline on this, if you want to send me
any results or screenshots directly (I assume youve noticed that the
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
On 11/13/12 10:15 AM, "Khalid" wrote:
Thanks Rob,
OK, thats a good thing. How many spaces and illuminance maps do you
i.e. one at a time, so youll have to wait for it to finish all the
maps before its fully done. After that, it will do a dimming
for
you.
When its all done you should see a "finished"
Keep us posted!
early next week.
Rob Guglielmetti
Research Group
Golden, CO 80401
303.275.4319
On 11/13/12 9:55 AM, "Khalid" wrote:
Thanks
31 December.
to December?
Rob Guglielmetti
Research Group
303.275.4319
On 11/13/12 6:52 AM, "Christopher Rush" >>>>>> wrote:
Im not sure about OpenStudio specifically, but it looks like
youre running an annual simulation. The last line seems to
represent timestep
1
(January)
8 at 11:00:00 AM. Wouldnt you expect it to keep going until it
gets to
12
Thanks Martin
to work.
Thanks
11/12/12
11/12/12
11/12/12
11/12/12
11/13/12
Hi Martin,
The last machine I use with a Mac system was the Mac LC (more than 20 years
ago)
Sent: Thursday, November 15, 2012 10:04 AM
Hi Khalid,
OSX side?
Martin
Hi, Rob
Regarding the sky condition in radiance which come with openstudio, is there
is a way to select the type of sky condition (clear, overcast, ...)
As far as I knew the illuminace map will be generated by EenergyPlus based
on the weather file, is there is a way have the result as a function of sky
type,
as done in daylight factor Calculation?
Thanks
Sent: Thursday, November 15, 2012 4:13 AM
Hi Khalid,
ease Date: 11/14/12
Hi Khalid,
Actually, if you check the "Use Radiance..." box in OpenStudio, then
Radiance will be used for all the daylighting calculations. That's why
it's important to review the "radout.sql" file for the daylighting data,
when Radiance is used.
The sky condition is derived automatically from the weather file. This is
the beauty of what John Mardaljevec calls "climate based daylight
modeling", or CBDM. The sky condition for each timestep is based on the
Perez all-weather sky model, which simply takes direct normal and diffuse
horizontal flux (irradiance or illuminance) as input. It is the ratio of
those two values that dictates the sky condition.
Daylight factors are computed from overcast sky daylight availability
only. This misses a lot of prevalent sky conditions, and as such is a
pretty useless metric for many climates. Hence, the move to CBDM which we
have embraced in OpenStudio (as have Christoph Reinhart, Alstan Jakubiec,
and Kera Lagios with DIVA, Rick Mistrick with the new DAYSIM, et al.).
Are we having fun yet, Khalid? =8-)
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 11/15/12 10:53 PM, "Khalid" <[email protected]> wrote:
Hi, Rob
there
sky
type,
Thanks
Hi Khalid,
ease Date: 11/14/12
Thanks Rob, for the information.
Regarding the Daylight Factor, the following discussion was in a paper I
read several years ago;
  "the average daylight factor .. is a useful design aid which is also
simple to use. Since the daylight distribution and intensity inside the
building will vary with time, whichever sky distribution is used as a basis
for design, then it would seem that great precision in this is
unnecessary.............. I have strong reservations over the provision of
detailed and complex daylight prediction system. What is required, in my
opinion, is a relatively simple system that architects must be encouraged to
use and to combine this with the provision of daylight controls to adjust
the daylight conditions when necessary. Electronic control of the electric
lighting should then integrate the electric lighting with the
daylighting for an energy-efficient design." (David Loe, in the discussion
in reference (1)).
As an architect I believe the daylight factor is more than a metric, and I
do think that its use in different climatic conditions could be improved.
Thanks
1- Kittler 1994 Kittler R. The Need for Standard Skies and Models for Energy
Conservation Measures. Lighting Research and Technology 1994;26(4):171-180.
Sent: Friday, November 16, 2012 7:11 PM
Hi Khalid,
Radiance will be used for all the daylighting calculations. That's why it's
important to review the "radout.sql" file for the daylighting data, when
Radiance is used.
the beauty of what John Mardaljevec calls "climate based daylight modeling",
or CBDM. The sky condition for each timestep is based on the Perez
Daylight factors are computed from overcast sky daylight availability only.
This misses a lot of prevalent sky conditions, and as such is a pretty
useless metric for many climates. Hence, the move to CBDM which we have
embraced in OpenStudio (as have Christoph Reinhart, Alstan Jakubiec, and
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Hi, Rob
there is a way to select the type of sky condition (clear, overcast,
...) As far as I knew the illuminace map will be generated by
EenergyPlus based on the weather file, is there is a way have the
result as a function of sky type, as done in daylight factor
Calculation?
Thanks
Hi Khalid,
ease Date: 11/14/12
Version: 2013.0.2793 / Virus Database: 2629/5896 - Release Date: 11/15/12
Hi Khalid,
You are right, metric was a poor choice of words regarding the DF. I also
agree that tools should allow architects to quickly estimate the impacts
of their designs, and that controls are crucial to any daylighting system
delivering a cost-effective solution. But lighting controls cannot be
simulated with a DF analysis because the performance of such systems is
highly dependent on actual daylight distributions within a space. This is
the main driver for us in integrating Radiance with OpenStudio (and, in
turn, EnergyPlus).
It is our hope that eventually OpenStudio will make it relatively painless
to do a much more thorough daylighting analysis than EnergyPlus is capable
of on its own.
Rob Guglielmetti
Golden, CO 80401
303.275.4319
basis
of
to
in reference (1)).
Thanks
Energy
1994;26(4):171-180.
Hi Khalid,
it's
Radiance is used.
modeling",
only.
Rob Guglielmetti
Group
Golden, CO 80401
303.275.4319
Hi, Rob
Calculation?
Thanks
Hi Khalid,
ease Date: 11/14/12
