Is there a faster way to calculate the illuminance value?
Hi everyone,
Based on the tutorial material, I learned the way to calculate the illuminance value of the points of the working plane is as follows. The working plane is 0.8 above the floor.
cat points3.pts | rtrace -h -I -ov -ab 3 scene1.oct | rcalc -e '$1=$1*179' > lux1.csv
In my case, the lighting sources are white light and the number of points is 1232. I compared the result of Radiance and the result from other commercial software like DIALux Evo and I found that when the value of -ab is 2 or 3 the results of Radiance and the commercial software start to be close. But when -ab=2, it takes more than 4 minutes to get the result, which is too slow for me. Therefore, I would like to ask if there is a faster way to calculate the illuminance of the working plane without changing the number of points and the number of ambient bounces.
Thanks in advance for your help. I appreciate it.
Warm regards,
Hao
Hi Hao,
The simplest change would be to add a -n option if you are running under Unix, which adds multiple processes to rtrace. This only helps if you have many input points, more than you have processors. For 8 processor cores, you can try:
rtrace -h -I -ab 3 -af cache.amb -n 8 scene1.oct < points3.pts | rcalc -e ‘$1=179*(.265*$1+.670*$2+.065*$3)’
The rtrace -af option specifies a file to share ambient values, which are shared between rtrace processes. Without this option, the speedup will not be very good. The formula in rcalc is to give you Luminance rather than just the red channel times 179.
Hi @Hao,
If you’re just looking for faster calculations with the Radiance algorithms, you could also try Accelerad.
Nathaniel
Thanks a lot for your reply. This is a very useful way. I will try this way.
Kind regards,
Hao
Hi Nathaniel,
Thank you very much for your help. The Accelerad looks is a very powerful tool. Thank you for letting me know about this promising way to accelerate lighting simulation.
Hao
Sorry to bother you again. I want to ask that if I don’t add a -n option how many processor cores will rtrace use? Is the default processor core 1?
Best regards,
Hao
Without the option, one processor is always used, and this is all you can use with the Windows version. However, you can use WSL (Windows Subsystem for Linux) to get full multi-processing support from Radiance. I do not know the details of how to do this, but the topic has been raised on the forum here and here.
Wow! These two links are very useful! Thank you so much for your reply. I appreciate it.
Best regards,
Hao
