X11 support on OSX 10.11?! (?!(?!))
Hey there, Radiance people. I'm setting up my work computer again, having just re-imaged it to MacOSX 10.11 (yes, 10.12 is (has been) around; don't ask). Built Radiance from source, all is well. Rvu works fine with the Qt driver. Realized I hadn't installed x11 yet. Installed x11 (xquartz), but my installation is now defaulting to the Qt driver for rvu output. Problem is, even forcing it to use x11 is failing with the dreaded "rvu: fatal - cannot start device "x11"" error. Look:
$ rvu frozen_octree.oct
(this works, loading the Qt-based rvu)
$ rvu -o qt frozen_octree.oct
(this works, as above)
But...
$ rvu -o x11 frozen_octree.oct
rvu: x11: not found
The x11 device is in fact running and mapped to $DISPLAY. Look:
echo $DISPLAY
/private/tmp/com.apple.launchd.2YPu12VOpL/org.macosforge.xquartz:0
So, WTF? Anyone?
This may be too simple to mention, but since I've done this to myself
before...
Is Xquartz running?
Stephen Wasilewski
*LOISOS *+* UBBELOHDE*
Alameda, CA 94501 USA
510 521 3800 VOICE
510 521 3820 FAX
On Thu, Dec 8, 2016 at 9:45 AM, Guglielmetti, Robert < [email protected]> wrote:
But...
rvu: x11: not found
echo $DISPLAY
So, WTF? Anyone?
It is. It's running, and is mapped to DISPLAY, as I mentioned below. What I've noticed is that CMake's x11 variables are all empty, probably because I initially configured/built Radiance before I'd installed X11 on this system here. So I'm ASSuming my rvu here was compiled without x11 driver support. Stay tuned...
From: Stephen Wasilewski <[email protected]<mailto:[email protected]>>
Reply-To: Radiance discussion <[email protected]<mailto:[email protected]>>
Date: Thursday, December 8, 2016 at 10:56 AM
Subject: Re: [Radiance-general] X11 support on OSX 10.11?! (?!(?!))
This may be too simple to mention, but since I've done this to myself before...
Is Xquartz running?
Stephen Wasilewski
LOISOS + UBBELOHDE
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com<http://www.coolshadow.com/>
On Thu, Dec 8, 2016 at 9:45 AM, Guglielmetti, Robert <[email protected]<mailto:[email protected]>> wrote:
But...
rvu: x11: not found
echo $DISPLAY
So, WTF? Anyone?
Hi Rob,
Looks like an issue with the way #define's are handled in devtable.c:
#if !defined(HAS_X11) && !defined(HAS_QT) && !defined(WIN_RVIEW)
/* weird logic ... */
#define HAS_X11
#endif
If you compile with -DHAS_QT, then you need to add -DHAS_X11 if you want that driver to compile as well. I'm not sure why it was set up this way, as I wasn't really involved with the changes supporting QT.
Date: December 8, 2016 10:05:56 AM PST
Is Xquartz running?
Stephen Wasilewski
LOISOS + UBBELOHDE
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com<http://www.coolshadow.com/&gt;
But...
rvu: x11: not found
echo $DISPLAY
So, WTF? Anyone?
Yep, thanks Greg! I just got back to this crap. I just rebuilt clean, now
that Qt AND x11 are on here, and it worked. Yes the def logic should be
re-written, and sorry that got jacked up like that, but that will affect
very few people so I¹m going to not worry about it for now.
Also I think I should have my head examined because I went through all
this because I actually *prefer* the x11 interface of rvu to the more
GUI-ish Qt one. Maybe that makes me some sort of hardcore Radiance dude.
More likely, just old. Dunno. =)
On 12/8/16, 11:18 AM, "Greg Ward" <[email protected]> wrote:
Hi Rob,
#define HAS_X11
#endif
<[email protected]<mailto:radiance-general@radiance-on
line.org>>
line.org>>
before...
Is Xquartz running?
Stephen Wasilewski
LOISOS + UBBELOHDE
510 521 3800 VOICE
510 521 3820 FAX
On Thu, Dec 8, 2016 at 9:45 AM, Guglielmetti, Robert >><[email protected]<mailto:[email protected]>> >>wrote:
But...
rvu: x11: not found
echo $DISPLAY
So, WTF? Anyone?
