Dear list,
this might be of interest to rad-openstudio, but I am refraining from cross-posting.
Whilst doing a bit of Radiance teaching last Friday, I got caught red-face in my attempt to use objview.rb. Installing ruby.zip from the NREL web site (and making sure %PATH% picks it up) did not help--objview.rb kept complaining about missing input files. It appears that somehow, ARGV is completely ignored by the parser once the options are dealt with. However, I know little about Ruby.
Since I need a working objview next Friday, I finished the re-write of objview in Perl, which I started some time ago, but never polished off.
Whilst at it, I also completed a Perl port of objpict.csh.
Both appear to work under LINUX and Windows Vista. Zip archive with Windows exe files is here:
http://www.jaloxa.eu/pickup/win_objpict_objview.zip
Your feedback would be much appreciated.
Since the Windows objview.rb has some extra functionality over the UNIX csh version (namely ltview), I started work on a x-plat ltview.pl, but have I admit that I'm not sure what it is meant to do:
a) if ltview is meant to show the actual luminaire (or fixture for you non-Europeans), then are not objview or objpict good enough?
b) if, on the other hand, it is the actual photometric distribution that matters, then would it not be better to extract the dat file of the distribution, and suspend a little disk or square with that distribution applied to it. The command line parser could then be extended to
- include an option that might cause it to put the disk inside a sphere rather than a box; and/or
- render a -vta fisheye view from just below this disk, so that the entire photometric distribution might be appreciated.
I'm happy enough to look into this if it is felt that the Windows version of objview and the 'official' one should be based on the same code. Would need some guidance, though as to what ltview should do.
Good night and good luck
Axel
PS: I'd love to call it 'iesview', but this name is already taken by an add-on to AGI32. Works pretty well, actually (under Windows).
@Ian, we probably have to thank you for this little gem?
