can i work in meters with radiance and get accurate results?, or is it limit to feets?
Ignacio Munárriz
Escuela de Arquitectura, Universidad de Navarra
Ignacio Munárriz
In principle your units can be arbitrary -- the RADIANCE code isn't hardwired to meters or feet. Having said that, it's up to you to make sure they're *consistent* with the other data you supply, for instance the light source emission. Note that radiometric units like radiance and irradiance are defined in terms of meters^2.
--Roland
Roland Schregle
END OF LINE. (MCP)
