I'm trying to use gensky as shown on chapter 3.1.3 of the Radiance book.
I have problems because the program can't find winxmit.cal.
Can anyone advice me on where I should keep winxmit.cal?
Alex
Alex
you should find it on the web site of radiance...
may be the RAYPATH is not set up... or the libraries are missing...
anyway:
winmix.cal is:
--------------------start of file-------------------
winxmit.cal - window transmittance function.
4/24/86
winxmit = 1.018 * Rdot * (1 + (1 - Rdot*Rdot)^1.5);
--------------------end of file------------------------------
after saving the file with the right name you can simply place it in your
scene directory or add the RAYPATH varable to your configuration file that
is used to define the location of radiance libaries
usually such file is
1 - .bash_profile
after a good back up of the file add:
RAYPATH=.:/your/system/path/to/radiance/libraries
export RAYPATH
or
2 - .cshrc
setenv RAYPATH .:/your/system/path/to/radiance/libraries:{RAYPATH}
hope it helps,
giulio
PS
different directories can be defined, just separate them with " : "
" . " stays for current directory.
From: Alexandre Kisslinger [mailto:[email protected]]
Sent: 31 March 2004 16:08
To: [email protected]
Subject: [Radiance-general] winxmit.cal
Alex
