Dear Andrew,
Finally I added the +forward and +backward in genBSDF sentence, but the
problem continued. Then I compared many XML files BSDFs and I noticed
missing the first line with information from the encoding of the file:
<? xml version = "1.0" encoding = "UTF-8"?>
I added that line manually and then, it was be exported to WINDOW smoothly.
It is rare that genBSDF did not put that line automatically. In this case,
I worked in Ubuntu 14.04 LTS and Radiance 5.0.
Daniel
2015-05-13 16:00 GMT-03:00 <[email protected]>:
[email protected]To subscribe or unsubscribe via the World Wide Web, visit
[email protected]You can reach the person managing the list at
[email protected]When replying, please edit your Subject line so it is more specific
than "Re: Contents of Radiance-general digest..."Today's Topics:
1. Re: WINDOW 7.3 shut down with BSDF of Venetian blind created
with genBSDF (Andrew McNeil)
2. Re: Question concerning installing Radiance in Mac (Greg Ward)
3. Re: Question concerning installing Radiance in Mac (Andrew McNeil)----------------------------------------------------------------------
Message: 1
Date: Wed, 13 May 2015 10:49:58 -0700
Subject: Re: [Radiance-general] WINDOW 7.3 shut down with BSDF of
Venetian blind created with genBSDF
Message-ID:
<CAOG+Niz5CWnkanJVOP4kYCmJh2hWKG9q2XosPJMWH32n=
[email protected]>
Content-Type: text/plain; charset="iso-8859-1"Daniel,
I'm surprised that WINDOW would crash like that. But one problem is that to
import a BSDF into WINDOW it must have both front and back transmission and
reflection. To get this you should use both the +f and +b options in
genBSDF.Best,
AndyOn Wed, May 13, 2015 at 7:54 AM, Daniel Uribe <[email protected]> wrote:
> Hello Everyone,
> I have already created a BSDF project which contains a Venetian blind
with
> a genBSDF,in which I enter the geometry, the material and the glazing. To
> do this I have used the next command (in addition,I attached the
respective
> files)
> Dropbox - Error - Simplify your life
> genBSDF -n 8 materials.mat glazing.rad Layer0.rad > Case1.xml
> Apparently,It worked right since I can see it in BSDF Viewer.
> However , the problem happen when I connect this BSDF with the window
> which contains WINDOW 7.3 software.So, when I try to add a shading since
> XML file, the program shut down.
> I have looked over each step but I dont know where can be the mistake.Do
> you have any idea about this problem or what is happening?
> Thanks you in advance,
> King regards,
> Daniel
> Daniel Uribe C?ceres
> Estudiante de Ingenier?a Civil
> Diploma en Ingenier?a Estructural
> Pontificia Universidad Cat?lica de Chile
> [email protected]
URL: <
http://www.radiance-online.org/pipermail/radiance-general/attachments/20150513/18db179e/attachment-0001.html
Message: 2
Date: Wed, 13 May 2015 10:55:57 -0700
Subject: Re: [Radiance-general] Question concerning installing
Radiance in Mac
Content-Type: text/plain; charset="windows-1252"Hi Zhe,
It looks like apple removed some GL support in the version of OS X you are
using, which is too bad. You will need to edit src/util/Rmakefile and
remove the program "glrad" from the PROGS= setting near the top. Then,
rerun "rmake install" in that directory.You didn't include all of your compile listing, so it's difficult to know
why rpict is not found, but did you remember to do as it suggested at the
end and add "/Applications/radiance/ray/bin" to your PATH variable? I
don't know why you decided to put everything there rather than /usr/local,
but in any case, the shell won't find commands unless it knows where to
look for them.Cheers,
-Greg> From: zhekong <[email protected]>
> Subject: [Radiance-general] Question concerning installing Radiance in
Mac
> Date: May 13, 2015 9:10:03 AM PDT
> To: [email protected]
> Hi all:
> I?m starting to learn Radiance and tried to install it in Mac. I
followed the video of installation online and got errors in attachment. I
ran a test and got another error in the second attachment.
> Could someone let me know how I should fix it?
> Thank you in advance.
> Zhe
URL: <
http://www.radiance-online.org/pipermail/radiance-general/attachments/20150513/a6145a0b/attachment-0001.html
Message: 3
Date: Wed, 13 May 2015 11:14:17 -0700
Radiance in Mac
Message-ID:
CAOG+NizehsjneY2PEGNghWG6mqkBRY1BNjRNxX6WM4aozBFiiQ@mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"Zhe,
The one error that is visible in your screenshot isn't what cause rpict to
fail to compile. There are probably more errors above in the terminal
window if you scroll up. Can you copy all the text from when you started to
compile alll the way to the end into an email? Just use copy paste rather
than attaching screenshot images.Thanks,
AndyOn Wed, May 13, 2015 at 9:10 AM, zhekong <[email protected]> wrote:
> Hi all:
> I'm starting to learn Radiance and tried to install it in Mac. I followed
> the video of installation online and got errors in attachment. I ran a
test
> Zhe
> [email protected]
URL: <
http://www.radiance-online.org/pipermail/radiance-general/attachments/20150513/0a6173c8/attachment-0001.html
http://www.radiance-online.org/mailman/listinfo/radiance-generalEnd of Radiance-general Digest, Vol 135, Issue 19
Daniel Uribe Cáceres
Estudiante de Ingeniería Civil
Diploma en Ingeniería Estructural
Pontificia Universidad Católica de Chile
