Haha, so you have a bible going? Good for you. I think many of us have
something similar, in some form or fashion. I managed to document a couple
of my notes online, here:
http://www.rumblestrip.org/interests/light/using-the-illum-material-for-smoother-renderings-in-radiance/
http://www.rumblestrip.org/interests/light/rtrace-multiprocessing-option-initial-test-results/
Francesco Anselmo's site is another repository:
http://www.bozzograo.net/radiance/index.php
Axel's stuff is awesome:
Radiance
(check out his "Radiance Cookbooks"!)
Giulio, I tried to link to your RadBlog (
http://web.mac.com/geotrupes/iWeb/Main%20site/RadBlog/RadBlog.html\), but
I got a server error!
…and of course there is an effort underway to buff up the content right on
the radiance-online.org site.
As Greg Ward has said: "everything about Radiance is documented,
somewhere". Trick is when you find a nugget, save it someplace!
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 1/2/13 8:36 PM, "Ji Zhang" <[email protected]<mailto:[email protected]>> > wrote:
Hi, Rob, ... already put into the "Radiance Bible" ...
On Thu, Jan 3, 2013 at 3:55 AM, Guglielmetti, Robert < > [email protected]<mailto:[email protected]>> wrote:
Can we have this reply laminated onto cards? =8-)
Thanks Andy!
Rob Guglielmetti
Golden, CO 80401
303.275.4319<tel:303.275.4319>
On 1/2/13 12:23 PM, "Andrew McNeil" <[email protected]<mailto: > [email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
Hi Ji,
179 is the efficacy of white (equal energy) light over the visible
spectrum.
Daylight is composed of a broader spectrum, so the efficacy (visible light
per watt of energy) is lower. Usually around 90 for the sun and 110 for
the sky, but changes based on various factors.
179 is used in Radiance as a convention since we are simulating visible
light. So when you're defining you sky using gensky with weather data you
need to either use the measured illuminance values and divide by 179 to get
radiometric units for the visible spectrum, or use the measured radiance
values (for solar spectrum), multiply by an approximate efficacy, then
divide 179 to get radiometric units for the visible spectrum only.
If you use gendaylit all the conversions are done for you.
Andy
On Tue, Jan 1, 2013 at 8:36 AM, Ji Zhang <[email protected]<mailto: > [email protected]><mailto:[email protected]<mailto:[email protected]>>> > wrote:
Dear list, Happy New Year!
I have a simple question related to conversion from irradiance value to
illuminance value, and pls correct me if I'm wrong:
Usually we can estimate the illuminance (lux) for a given point by
multiplying the irradiance (w/m2) for the point as simulated via Radiacne
by 179 (lm/w) which is the luminous efficacy used in Radiance, or more
strictly (R*0.265+G*0.670+B*0.065)*179.
However, it seems that in a epw weather file the "global horizontal
illuminance" value is not equal to but smaller than the "global horizontal
radiation" value multiplied by 179.
May I ask:
1. why there's such a large discrapency?
2. Will this lead to over-estimation of illuminance when using cumulative
sky derived from "global horizontal radiation" ?
Thanks in advance!
- Ji
[email protected]>>
[email protected]>
