I was just writing an reply when David sent his mail...
So I just wanna add, that for a full spectral simulation you definitely should add the spectral transmission of the glazing (and also the spectral behaviour of all other materials) and to be sure about the used sun and sky spectrum. In my point of view, the spectral sky model is the largest uncertainty at the moment (besides the general discussion about the c(lambda) itself).
@Mark and Greg: Did the Utah sky model undergo a validation by the use of spectral and luminance data? I know that currently TU Berlin is acquiring a huge dataset containing such data in order to develop a spectral sky model.
Jan
Sent: Thursday, June 25, 2015 9:12 AM
Subject: Re: [Radiance-general] Weighting factors used in the irradiance calculation
Hi Parisa,
when we worked on the spectral evaluations back then, we were testing our spectral version of Radiance (which is unfortunately based on Radiance 3.8 and has not been updated since then...). Our idea back then was to check whether there are RGB coefficients that provide reasonable results for calculating spectrally weighted values. With the coefficients as given in the paper you can definitely get an estimation, but there are already deviations from the correct spectral calculations if you only look at the light source spectra themselves. This might even get worse if interreflections significantly contribute to the illumination. This is also true for illuminances and color, which in fact are nothing else but special spectral weighting functions (see therefore Greg's paper "Picture Perfect RGB Rendering Using Spectral Prefiltering and Sharp Color Primaries" at Picture Perfect RGB Rendering Using Spectral Prefiltering and Sharp Color Primaries or Arne's and mine "Color-rendering indices in global illumination methods" at http://dx.doi.org/10.1117/1.3274623\)
So, if you really need to be sure about your values (as far as this is possible within a simulation...), I would always suggest to use spectral rendering and use the c(lambda) weighting function (as also stated in the conclusion of the paper). Following the proposal by Ruppertsberg&Bloj you can just run several 3-channel runs with a recent version of RADIANCE and put them together to you spectral result.
David
2015-06-24 19:15 GMT+02:00 Greg Ward <[email protected]<mailto:[email protected]>>:
Hi Parisa,
If you are only comparing one set of C-lambda values to another, then the scaling does not matter. If, on the other hand, the RGB coefficients from David & Arne's paper were somehow computed to correlate with other aspects of irradiance, such as photopic adaptation, then you probably should use them as given. I guess I need to read their paper....
A full spectral calculation probably is not needed in this case, but it would help to have a good estimate of the sky color either way. You should check out Mark Stock's implementation of the Utah sky model using Radiance:
http://markjstock.org/radiance
From: parisa khademagha <[email protected]<mailto:[email protected]>>
Date: June 24, 2015 6:04:12 AM PDT
Hi Greg and Jan,
Thank you for your detailed replies!
Here is my precise application: I want to use Radiance to estimate/simulate the effective irradiance with respect to the C-lambda.
First option is to use different (-0.034 IR + 0.323 IG + 0.558 IB) weighting functions for C-lambda as suggested by Geisler-Moroder & Dur (2010) in their paper (entitled ‘Estimating melatonin suppression and photosynthesis activity in real-world scenes from computer generated images’). My question is whether using these C-lambda weighting functions is a correct way of getting effective irradiance with respect to C-lambda in W/m2 or not?
Second option is to use the spectral rendering as suggested by Ruppertsberg & Bloj (2008) in their paper (entitled ‘Creating physically accurate visual stimuli for free: Spectral rendering with RADIANCE’) . In this case my question is how can I spectrally model the sky?
Parisa
On 22 June 2015 at 23:57, Greg Ward <[email protected]<mailto:[email protected]>> wrote:
If I may jump in, here...
Ultimately the 179 lumens/watt conversion derives from the peak defined efficacy of 683 lumens/watt at 555nm and my particular choice of endpoints for the visible spectrum in integrating an equal energy source. Since the power-to-photopic conversion is very sensitive to the choice of endpoints (for the very reason that viewers are *not* sensitive to those endpoints), I thought to standardize it at some point and end the confusion. Divide by 179 going from photometric units and multiply by 179 going to and the two factors cancel, problem solved.
That said, the factor is somewhat arbitrary and Radiance does not really care what lighting units it works in. This is why Jan's trick of substituting solar reflectances and solar radiances works just fine. If you dig through most of the Radiance code, you will find very few references to wavelength, and in the end you can compute in infrared and ultraviolet and nothing will go wrong, so long as you can get by with 3 channels or don't mind doing multiple runs.
The RGB coefficients for luminance (ignoring the 179 conversion factor) add up to 1.0 again as a convention, but it's a common one for conversion between color spaces. In this case, we're converting RGB to one channel of CIE XYZ, the Y channel. The other matrix coefficients can be found in ray/src/cal/cal/xyz_rgb.cal, or ray/src/common/spec_rgb.c if you prefer C code.
If you would tell us your precise application, what you have as input and what you expect as output, it would help us to better answer your question.
From: Parisa Khademagha <[email protected]<mailto:[email protected]>>
Date: June 22, 2015 2:14:24 PM PDTHi Rob,
Thank you for your reply! Is the formula incomplete for calculation of the irradiance value or it is missing 179 luminous efficacy value for conversion of irradiance to illuminance? What if we decide to measure the effective irradiance with respect to another curve (for instance C-lambda)? Should the summation of the C-lambda weighting functions be also equal to 1? Is this a rule in Radiance or it can be violated?
ParisaOn 22 Jun 2015, at 18:10, Guglielmetti, Robert <[email protected]<mailto:[email protected]>> wrote:
Hi Parisa,
Yes, these values are the so-called V-lambda or photopic weighting function, and yes these three will always equal 1 (naturally your derived result will generally be > 1).
*Be advised*, your formula as printed in your post is incomplete; when converting irradiance as computed by Radiance (the software) to illuminance, you need to multiply the whole thing by 179 which is the luminous efficacy value to be used _with Radiance_. In other words:
I = 179 * (0.265 IR+ 0.670 IG + 0.065 IB)
There are scores of posts in the archives about this value and how it came to be, and why it works even though it's different from any luminous efficacy value you've ever seen in a textbook on light. =)
On 6/22/15, 9:50 AM, "parisa khademagha" <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
Dear all,
I have two questions regarding the weighting factors (0.265, 0.670, 0.065) that are used in the formula ( I = 0.265 IR+ 0.670 IG + 0.065 IB) with which one can convert the spectral irradiance triad to irradiance. My first question is: where these weighting factor come from? Do they incorporate the spectral sensitivity of the human eye (so called V(λ)) in the irradiance calculation? My second question is: should the summation of these weighting factors be always equal to 1.
Thank you in advance,
Parisa
Dipl.-Ing. Dr. David Geisler-Moroder
Hofwaldweg 14/20
6020 Innsbruck
Austria
