Hi David,
If I understand your e-mail correctly, you are seeing this error using the NEW material, not the OLD one.
I cannot reproduce your error. I assume from your earlier e-mails that you are using the latest HEAD of Radiance. You should make sure that everything is up-to-date and try it again. In particular, we fixed some problems last December in the normalization of results. The dctimestep program has also been improved and corrected.
Date: May 23, 2011 7:51:13 AM PDT
Dear Radiance users,
I am getting warning message
warning - outgoing BSDF direction 142 collects 107.4% of light
when multiplying matrixes by dctimestep. I generated BSDF matrix by genBSDF.
I guess that I can still use it but is this message saying that it could be wrong or is it more just like a statement that there is literally more light coming to direction 142.
I generated more of BSDF matrexis and I kept same geometry and changed only one material which has higher reflectance. I guess that it can be reason but I would like to be sure that the BSDF matrix is still reliable.
Here is the material description for OLD and NEW (with warning message when used)
NEW material is generated by "optics2rad"
OLD material is generated by script "glaze" and "optics2glazedb"
Thank you very much I very appreciate your help
David
void BRTDfunc OLD
10
sr_frit_r sr_frit_g sr_frit_b
st_frit_r st_frit_g st_frit_b
0 0 0
glaze1.cal
11
0.0564
0.0492
0.051
0.126
0.126
0.126
0.054
0.054
0.054
1 .6
void BRTDfunc NEW
10
rR_clear rG_clear rB_clear
0.678*tR_clear 0.655*tG_clear 0.576*tB_clear
0 0 0
window.cal
15 0 0 0 0 0 0 0 0 0
0.267 0.321 0.395
0.24 0.306 0.368
Hi David,
I don't really know the source of this warning. Concentration of light shouldn't affect genBSDF, as it measures everything at infinity. Why don't you e-mail me your problem XML file in an off-list message, and I'll see if I can spot anything.
Date: May 23, 2011 8:53:33 AM PDT
Yes, you understand my email correctly.
I have just find that the material is probably not only the reason. I have the window split into parts parts and only BSDF for bottom part (down) generate this warning. Here is the command for both parts of window, and only difference is the bounding box, which I assume is correct.
### this one produce the warning
genBSDF -c 1000 -n 8 -r @BSDFparameters.opt +forward -backward -geom -dim 0 1.98 0 1.13 -0.01 0 \
geometry/materialNew.mat geometry/30_geometry.rad > results/BSDFdown_30_new.xml
genBSDF -c 1000 -n 8 -r @BSDFparameters.opt +forward -backward -geom -dim 0 1.98 1.13 2.26 -0.01 0 \
geometry/materialNew.mat geometry/30_geometry.rad > results/BSDFup_30_new.xml
I am actually using dctimestepcpu instead of dctimestep because it is much faster, but I guess it is updated too.
I have got this message before but with dctimestep and not dctimestepcpu. I fixed that in that time but I am not sure what was wrong, I guess it was something with wrong geometry and there were many more dirrection which collected higher %.
My question could be also understand as: Would this error also appear when there is light concentration in one spot after it is reflected?
Thank you
David
On 23 May 2011 08:32, Greg Ward <gregoryjward@gmail.com> wrote:
Hi David,
Hi David,
I don't get the warning using your XML file. I suspect there is something amiss with dctimestepcpu, which I don't know anything about. Maybe it was derived from earlier code that summed up the BSDF improperly?
Date: May 23, 2011 9:50:43 AM PDT
Hi Greg
here is the file. This matrix is only the difference compare to other calculations.
I really appreciate your help with my problems with Radiance.
Thank you
David
On 23 May 2011 09:35, Greg Ward <gregoryjward@gmail.com> wrote:
Hi David,
> From: David Appelfeld <d.appelfeld@gmail.com>
> Hi Greg,
> Thank you
> David
> Hi David,
> -Greg
