I've been using rtcontrib to look at different window contributions in a space under an overcast sky. When I 'pcomb' the resultant images and compare the illuminance values to an image generated with 'rad' I get light levels 1/3 of what I'm getting in the rad generated image.
For the rtcontrib routine I used:
oconv mat.rad d_cie.rad d_c1.rad d_c2.rad d_c3.rad d_c5.rad d_c6.rad d_c7.rad d_c9.rad d_c130.rad d_c131.rad d_c132.rad d_c133.rad d_c134.rad d_c255.rad > punch_40.oct
Could the -I+ option you're giving to rtcontrib be substituted with the -i+ option? The former would compute an array of irradiance values surrounding your -vp setting, rather than an irradiance image of intersected surfaces. I wouldn't think the images would look very similar in this case. Did you compare the appearance of rtcontrib -I+ versus rpict -i?
Date: June 11, 2010 12:51:28 PM PDT
