hi again
i want to know about the various Viewers for Radiance output such as *.oct
etc so as to map down values and without showing any garbage.
or which is best viewer for radiance output to compare results or which
gives out values without any garbage
thanks
dhaRam
G11
2
garbage is good.
be ready to type a lot of garbage when you are learning!
rvu is a good start
good luck
On 19 May 2011, at 20:33, dharam wrote:
hi again
i want to know about the various Viewers for Radiance output such as *.oct etc so as to map down values and without showing any garbage.
or which is best viewer for radiance output to compare results or which gives out values without any garbage
thanks
dhaRam
