How to produce the error?
The problem I am facing is the when I give an identifier name to view variable in .rif file and when I use rad to render it. there’s no output.
Files that I have:
This is my scene.rif file:
# Specify where the compiled octree should be generated
OCTREE=scene.oct
# Specify an (I)nterior or (E)xterior scene, along with the bounding box of the scene, obtainable via `getbbox scene.rad`
ZONE=E -1.3671875 1.3671875 -0.8515625 0.8515625 -0.984375 0.984375
# A list of of the rad files which make up our scene
scene=scene.rad
# Camera view options
view= viewName -vp 7.358891487121582 -6.925790786743164 4.958309173583984 -vd -0.6515582203865051 0.6141704320907593 -0.44527149200439453 -vu -0.32401347160339355 0.3054208755493164 0.8953956365585327
# Option overrides to specify when rendering
render=-av 1 1 1 -pa 1.0
# Choose how indirect the lighting is
INDIRECT=2
# Choose the quality of the image, from LOW, MEDIUM, or HIGH
QUALITY=MEDIUM
# Choose the resolution of mesh detail, from LOW, MEDIUM, or HIGH
DETAIL=MEDIUM
# Choose the light value variance variability, from LOW, MEDIUM, or HIGH
VARIABILITY=MEDIUM
# Reolution of the image
RESOLUTION=240 240
# Where to output the raw render
RAWFILE=output_raw.pic
# Where to output a filtered version of the render (scaled down for antialiasing, exposure correction, etc)
PICTURE=output.pic
# The time duration in minutes before reporting a status update of the render progress
REPORT=0.1
And in order to render the file scene.rad file that contains the scene data of an object, we use the command:
rad -v viewName scene.rif
And there’s no output.
But when I remove the identifier name from view, and use “rad scene.rif”, there’s perfect output.
You can clone all the files from here - GitHub - chiragsingh1711/Radiance-Rendering
