Hello Radiance users,
I am trying to generate sky distribution during sunny day for my model to
compare the results with the measured data of illuminance. It seems that the
day when the measurements were obtained was very clear and I would like to
decrease the turbidity in gensky to get higher global and vertical
illuminance.
When I decreased the turbidity from the default of 2.45 to 1 then the
illuminance decrease, while when I increase -t option then the illuminance
increase too. I would actually expect opposite, and that the illuminance
will increase with lower turbidity since the turbidity should scattered
light more and thus block the direct contribution and increase the diffuse
contribution form the sky.
Here is the gensky command I am using:
gensky 9 5 $(printf "%02d:%02d" $h $m)CEST -a 55.964875 -o -12.4934 -m -15
+s -t 1
Does someone have had this problem before? Or is this as gensky should
works?
Thank you
David
Hi David,
It may seem counterintuitive, but the way gensky works is that the solar intensity is unaffected by turbidity. Decreasing turbidity actually reduces the sky zenith brightness using a simple model, which makes sense since no atmosphere would look like a night sky even in the daytime. Thus, since we don't properly account for the loss in solar intensity as turbidity is reduced, the total illuminance goes up.
Generally speaking, you shouldn't bother with the turbidity setting at all. Since it only affects the default sky brightness and not the sky distribution, it makes more sense to control these values directly using any of the -b, -B, -r, or -R options for setting radiance or irradiance.
Date: May 5, 2011 4:56:01 PM PDT
I am trying to generate sky distribution during sunny day for my model to compare the results with the measured data of illuminance. It seems that the day when the measurements were obtained was very clear and I would like to decrease the turbidity in gensky to get higher global and vertical illuminance.
When I decreased the turbidity from the default of 2.45 to 1 then the illuminance decrease, while when I increase -t option then the illuminance increase too. I would actually expect opposite, and that the illuminance will increase with lower turbidity since the turbidity should scattered light more and thus block the direct contribution and increase the diffuse contribution form the sky.
gensky 9 5 $(printf "%02d:%02d" $h $m)CEST -a 55.964875 -o -12.4934 -m -15 +s -t 1
Does someone have had this problem before? Or is this as gensky should works?
Thank you
David
David
If you want to match measured values you should use the -R or -B options.
See the man page for details.
illuminance.
+s -t 1
works?
Thank you
David
Hi Greg and Thomas,
thank you for the answer. I was not sure if I can use -R option, because I
have available only global horizontal irradiation and illuminance and it
seems from gensky manual that I need to have direct irradiance measured
horizontally without the diffuse contribution.
In the case I can use -R option, will the gensky looks simple like this
gensky 9 5 12:30CEST -a 55.964875 -o -12.4934 -m -15 +s -R 600
thank you
David
On 5 May 2011 17:02, Greg Ward <[email protected]> wrote:
Hi David,
> From: David Appelfeld <[email protected]>
illuminance.
-15 +s -t 1
works?
> Thank you
> David
E(global-h) = E(diffuse-h) + E(direct-h)
or
E(global-h) = (-B value) + (-R value)
Note that this is different than the values used for gendaylit -W or -L which require direct *normal* and diffuse horizontal. But for gensky it seems the horizontal value is used for both diffuse and direct components, so take advantage of the additive nature of light.
I was not sure if I can use -R option, because I have available only global horizontal irradiation and illuminance and it seems from gensky manual that I need to have direct irradiance measured horizontally without the diffuse contribution.
Sent: Thursday, May 05, 2011 8:25 PM
