Hello.
Currently, I would like to use genBSDF to create BSDF data for a material that overlays plastic and mirror. However, even if I checked the created data on a simple flat plate with BSDFviewer, I could not confirm the effect of superposition, and the result was that only plastic was effective.
The following are the material settings and commands used.
###test.rad
void plastic test_p
5 0.167 0.167 0.167 0 0
void mirror test_pm
1 test_p
3 0.333 0.333 0.333
test_pm polygon object_1.1
12 1950 650 0
1950 0 0
0 0 0
0 650 0
###command
genBSDF +f +b -c 500 -geom millimeter -dim 950 1000 300 330 -1 0 test.rad > test.xml
Does genBSDF not support superposition materials?
I would appreciate your reply.
Best regards
