Dear forum,
Will Radiance work on a Unix emulator, say Exceed and Exceed 3D on Windows XP? Sorry of this question is irrelevant.
Thanks.
Jun
"Sent via BlackBerry from Smart"
Address: 8F Marajo Tower, 312 26th Street, West corner 4th Avenue, Bonifacio Global City, Taguig City, Philippines
(T): +632.659.0381 (F): +632.659.7249
Hi Jun,
Exceed is not a Unix emulator, but a X-Server. That means it can be used to display GUI-windows, most probably also those by Radiance. However, you still need to provide a rudimentary unix environment, unless you run the Radiance binary on a remote system and use the Xserver only for the Gui (e.g. by tunnelling the X-protocol through a X-session. That works fine with Radiance as any X-based program.
Dear Jun,
You will find a section titled 'Running Radiance on Windows' in my
'Running LEARNIX' document which you can access here:
http://www.jaloxa.eu/mirrors/learnix/docs.shtml
The instructions walk you through compiling Radiance under Windows in
a Cygwin enivironment, and also detail how to get the Xserver running.
An alternative would be to run LINUX in a virtual machine such as
VirtualBox. This will allow you to use rpiece (or, more conveniently,
rpictmt which is a wrapper around rpiece) to utilise all processor
cores for parallel rendering. I'm doing this every day because my
machine at work has Windows on it. It works rather nicely. This
approach is also explained in the same document.
Cheers
Axel
Thanks Lars!
I was stuck at a step during installation of Cygwin and MinGW and was looking for other options. Guess I'll have to resume the installation and might probably ask the forum again if I can't make it work.
Thanks again,
Jun
Date: Wed, 17 Aug 2011 08:55:25
To: Radiance general discussion<[email protected]>
Cc: <[email protected]>
Subject: Re: [Radiance-general] Unix emulator
Hi Jun,
Dear Axel,
There's a wealth of info in there. Will try them out. Thanks a bunch!
Best regards,
Jun
Sent: Thursday, August 18, 2011 4:22 PM
To: [email protected]
Dear Jun,
Cheers
Axel
