Under what condition, when the input files for octree are changed, the oct file should be compiled again?
Hi everyone,
I am doing a simple case in Radiance, there is a rectangular house and an array of lighting on the ceiling. I use the following command to get the oct file:
oconv course.mat lights.rad room.rad > scene1.oct
The lights.rad file is like:
!xform -t 1.2 1.3 2.75 -a 5 -t 2.4 0 0 -a 3 -t 0 2.7 0 erco.rad
But I have a question: if I change some parameters of the erco.rad file, it seems that I do not need to use oconv to compile the files again. So, I would like to ask which files are changed will lead to compiling the octree files again.
I remember that in the radiance_tutorial.pdf or radiance_cookbook, there is an introduction to this question. But I checked these two materials three times and didn’t find the part related to this question. So I have to ask you guys for help again. Thanks in advance for your help and efforts.
Hao
Hi Hao,
You must re-run oconv if you change the number of modifiers or surfaces, or change any of the geometry in your scene. If you use the oconv -f option, you must always rerun it to see the changes.
Thank you very much for your reply. It is glad to mast another piece of knowledge of the Radiance.
Kind regards,
Hao
