Dear Radiance users and experts,
As an engineer in a the building industry, I use Radiance to model different facades options in terms of daylighting. I also use Daysim for annual calculations to estimate annual illuminance exposure and other metrics (DA, etc.).
I'm currently working on a translucent glazing option and below is my understanding of the several possibilities I have to model it with Radiance.
Please feel free to correct me.
The easiest way is to use trans but I understand that this does not allow one to model an angle-dependant transmittance and reflectance.
To overcome this limitation, I could use transfunc or transdata but the angle-dependant transmittance/reflectance only applies to the specular components and not the diffuse ones.
I understand that BRTDfunc suffers from the same limitations even if it allows the user specifying more distribution functions (mirror, reflectance, transmittance lobes).
From my understanding then only a BSDF material allows a complete material description. This can be achieve with Window and (or?) the genBSDF routine.
Moreover, on the use of transdata/transfunc, I understand from the Radiance documentation that the only modified value is the transmitted specular component so the last one called tspec. Is that correct ?
I've carried out some calculation with a trans and transdata material following the process described in Reinhart's paper (Development and validation of a Radiance model for a translucent panel).
trans:
void trans south_panel
7 0.40446 0.40446 0.40446 0.08 0 0.435635 0
transdata
void transdata south_panel
4 noop refl.dat rang.cal rang
6 0.40446 0.40446 0.40446 0.08 0.435635 1
Reading the paper, I though that the values contained into the refl.dat file where multipliers of the transmitted specular fraction (tspec) set to 1 (last parameter of the transdata). Then I ran a simulation with a sunny sky with sun (simple square box with a window).
In the case of the trans material, with no transmitted specular component, I was expecting to see a perfect diffuser which was the case.
In the transdata case, I expected to see a patch of light on the floor as the transmitted specular fraction was not zero (from my understanding at least). Instead, the transdata material seemed to behave as a trans material with no transmitted specular component.
Am I missing something ?
These results really confuse me.
Thank you all for your support.
Thibault
42-43 Gloucester Crescent
London
NW1 7PE
T +44 (0) 20 7267 5161
F +44 (0) 20 7482 0329
maxfordham.com
Max Fordham LLP is a Limited Liability Partnership. Registered in England and Wales Number OC300026
Registered office 42-43 Gloucester Crescent, London, NW1 7PE
