Hello all,
I have a question regarding how the time format affects local solar time and solar position in gendaylit. It seems that different time representations for non-integer hours lead to variations in the calculated solar time and solar position. This behavior appears to be different from gensky.
For example, when simulating for Tokyo, Japan on September 15th, the header generated by gendaylit shows different local solar time and solar position depending on the time format used. However, gensky does not exhibit this difference.
#gendaylit 9 15 11:30 -m -135 -o -139.76 -a 35.69 -W 378 363 -O 1
#Local solar time: 11.39
#Solar altitude and azimuth: 55.5 -16.2
#gendaylit 9 15 11:30JST -m -135 -o -139.76 -a 35.69 -W 378 363 -O 1
#gendaylit 9 15 11:30JST -o -139.76 -a 35.69 -W 378 363 -O 1
#Local solar time: 28.39
#Solar altitude and azimuth: -18.0 -106.5
#gendaylit 9 15 11.5 -m -135 -o -139.76 -a 35.69 -W 378 363 -O 1
#Local solar time: 11.89
#Solar altitude and azimuth: 56.5 -2.9
#gensky 9 15 11:30 -m -135 -o -139.76 -a 35.69
#gensky 9 15 11:30JST -o -139.76 -a 35.69
#gensky 9 15 11.5 -m -135 -o -139.76 -a 35.69
I suspect that gendaylit requires the time to be specified in decimal format (e.g., 11.5 for 11:30) rather than the HH:MM format to produce accurate results.
Could someone confirm if this is the correct approach, or clarify why this difference occurs?
Any clarification or guidance would be greatly appreciated.
Thank you for your time and help!
Best regards
