Three phase method
Dear list,
I am trying to use the three phase method to evaluate a dynamic shading
device.
I have already created the vmx, xml, dmx, and skv. Then I try to use
dctimestep to create the final render, but it does not return any image. I
typed:
pcomb '!dctimestep images/vmx/windowglow_W_%03d.hdr
xml/low-e+venetain80.xml results/windows.dmx skies/6_21_14.skv'
'!dctimestep images/vmx/windowglow_C_%03d.hdr xml/low-e+clear-lc.xml
results/clerestories.dmx skies/6_21_14.skv' >
images/6_21_14_Milwaukee_V80-clearLC.hdr
The only thing it returns is a bunch of signs like this:
???ܿ???½??в?Ļ?Ɵ??ú??ƿ???ȯ?ƺ???ʯ???ë???ϩ?õۿ???&???Ѻᬻ???~???Կ???z???ý??Ƕέ??µ???|??y}yyz???~???|???v???Ͽ???˳??Ŀ?ϼȻ???Ź??л??¯???õ???ǴĪ???ԩ???Я?غ&???..
Does anyone know what might be wrong?
Thank you,
Leyla
I found the problem. Please disregard my previous post.
Leyla
On Sun, Jul 21, 2013 at 6:31 PM, Leyla Sanati <[email protected]> wrote:
Dear list,
device.
typed:
???ܿ???½??в?Ļ?Ɵ??ú??ƿ???ȯ?ƺ???ʯ???ë???ϩ?õۿ???&???Ѻᬻ???~???Կ???z???ý??Ƕέ??µ???|??y}yyz???~???|???v???Ͽ???˳??Ŀ?ϼȻ???Ź??л??¯???õ???ǴĪ???ԩ???Я?غ&???.......
Thank you,
Leyla
Hello all,
I have some more questions regarding the three phase method,
I understand that I cannot simulate bending pipes with the genbsdf. However I also need to simulate straight pipes that I think is able to be done.
My question is if I need to specify the depth of the pipe somehow in any of the steps at the three phase method and how to do that.
The way I create the geometry used at the daylight matrix and view matrix (meaning the two ends of the pipe) are in the "proper distance". But is this the correct way to do it (?) or the "entrance" of the pipe at the view matrix should be at the same position as the "exit" of the pipe at the daylight matrix (?) and then I specify the length of the pipe (that the "light" will travel through the pipe) between the "entrance" and "exit"? I suppose that maybe this way I could generate one bsdf of a long pipe and then use it for different length of pipes?
Another question that I have is if I can use two different parallel BSDFs on one simulation.
Thank you in advance,
Vayia
Hi Vayia,
You should consider using the new rfluxmtx to generate a transmission
matrix for your lightpipe the resulting matrix won't be in a BSDF XML file
format, but I don't think you need that format anyway. One benefit is you
can specify any geometry for the entrance and exit (genBSDF requires
parallel, rectangular ports).
A general (untested) approach is below.
Finally, I'm not sure what you mean by two different parallel BSDFs. Can
you elaborate?
Andy
insideport.rad:
#@rfluxmtx h=fk u=Y
materials & geometry
outsideport.rad:
#@rfluxmtx h=fk u=Y
sky.rad:
#@rfluxmtx h=u u=Y
ground hemisphere
#@rfluxmtx h=r1 uY
sky hemisphere
cat sensorpoints.txt | \
rfluxmtx -faa -ab 12 -ad 50000 -lw 2e-5 -I \
-y `wc -l < numeric/Space_1.map` \
- insideport.rad \
materials.rad model.rad > view.mtx
rfluxmtx -ab 12 -ad 5000 -lw 2e-5 insideport.rad outsideport.rad \
materials.rad model.rad > lightpipe.mtx
rfulxmtx -ab 2 -ad 1000 -lw 1e-3 outsideport.rad sky.rad \
materials.rad model.rad > daylight.mtx
rmtxop view.mtx lightpipe.mtx daylight.mtx > dcoef.mtx
dctimestep dcoef.mtx sky.mtx > illuminance.txt
On Wed, Aug 20, 2014 at 4:46 AM, Vayia V <[email protected]> wrote:
Hello all,
done.
on one simulation.
Vayia
Thank you for the reply and the help,
About the two BSDF, I have for example a BSDF for the pipe and then I have one more BSDF for the top (or bottom) part of the pipe. Can I somehow merge them and use them both?
As for the rfluxmtx, is there any tutorial available?
Kind regards
Vayia
Date: Wed, 20 Aug 2014 18:14:43 -0700
Subject: Re: [Radiance-general] Three phase method
Hi Vayia,
You should consider using the new rfluxmtx to generate a transmission matrix for your lightpipe the resulting matrix won't be in a BSDF XML file format, but I don't think you need that format anyway. One benefit is you can specify any geometry for the entrance and exit (genBSDF requires parallel, rectangular ports).
Finally, I'm not sure what you mean by two different parallel BSDFs. Can you elaborate?
Best,Andy
insideport.rad:#@rfluxmtx h=fk u=Ymaterials & geometry
outsideport.rad:#@rfluxmtx h=fk u=Ymaterials & geometry
sky.rad:#@rfluxmtx h=u u=Yground hemisphere#@rfluxmtx h=r1 uYsky hemisphere
cat sensorpoints.txt | \ rfluxmtx -faa -ab 12 -ad 50000 -lw 2e-5 -I \
    - insideport.rad \
Hello all,
Vayia
This program seems pretty useful. Is there any manpage or something?
Also, is it possible to do something like this by modifying/re-writing
genBSDF script? I am not quite sure what was the motivation of writing a
whole new program. Could you elaborate a little bit, Andy?
THANKS A LOT
Germán
2014-08-21 6:34 GMT-04:00 Vayia V <[email protected]>:
Kind regards
Vayia
Hi Vayia,
you elaborate?
Andy
insideport.rad:
#@rfluxmtx h=fk u=Y
outsideport.rad:
#@rfluxmtx h=fk u=Y
sky.rad:
#@rfluxmtx h=u u=Y
ground hemisphere
#@rfluxmtx h=r1 uY
sky hemisphere
- insideport.rad \
Hello all,
done.
on one simulation.
Vayia
_______________________________________________ Radiance-general mailing
list [email protected]
*Germán Molina L.*
Ingeniero Trainee
Hunter Douglas Chile S.A.
Celular +569 89224445
gracias.
Hi Germán,
There is a man page for rfluxmtx, but that's about all we have at this point. I sent Vayia some slides I plan to present at the workshop in London, and I can send this to others who are interested. (I'm following my own recommendation not to include attachments in radiance-general posts, and my website is inaccessible at the moment for unknown reasons.)
Rfluxmtx was created to simplify common sampling operations used with rcontrib, and will ultimately be used to simplify the internals of the genBSDF script, which is a less general tool. The only program rfluxmtx completely replaces is genklemsamp.
Date: August 21, 2014 2:23:31 PM GMT+02:00
Also, is it possible to do something like this by modifying/re-writing genBSDF script? I am not quite sure what was the motivation of writing a whole new program. Could you elaborate a little bit, Andy?
THANKS A LOT
Germán
Kind regards
Vayia
Hi Vayia,
Andy
insideport.rad:
#@rfluxmtx h=fk u=Y
outsideport.rad:
#@rfluxmtx h=fk u=Y
sky.rad:
#@rfluxmtx h=u u=Y
ground hemisphere
#@rfluxmtx h=r1 uY
sky hemisphere
    - insideport.rad \
Hello all,
Vayia
Thanks Greg! I will have a look and check it out when I have time.
Will the presentations be recorded and published this year? I will not go,
but I would like to keep myself up to date.
THANKS
Germán
2014-08-21 8:49 GMT-04:00 Greg Ward <[email protected]>:
Hi Germán,
*Subject: *Re: [Radiance-general] Three phase method
*Date: *August 21, 2014 2:23:31 PM GMT+02:00
THANKS A LOT
Germán
Kind regards
Vayia
Hi Vayia,
you elaborate?
Andy
insideport.rad:
#@rfluxmtx h=fk u=Y
outsideport.rad:
#@rfluxmtx h=fk u=Y
sky.rad:
#@rfluxmtx h=u u=Y
ground hemisphere
#@rfluxmtx h=r1 uY
sky hemisphere
- insideport.rad \
Hello all,
done.
on one simulation.
Vayia
*Germán Molina L.*
Ingeniero Trainee
gracias.
Yes, we are planning to record and possibly webcast the workshop. People are working on it, and we'll make an announcement if there is the possibility to follow the talks live.
Date: August 21, 2014 3:00:32 PM GMT+02:00
Will the presentations be recorded and published this year? I will not go, but I would like to keep myself up to date.
THANKS
Germán
Hi Germán,
THANKS A LOT
Germán
