Three-Phase Method: dmx
Dear Radiance List
I'm coming with another question that is probably too simple but still
keeps me from moving to the next phase of the 3Phase:
When I create the daylight matrix using genklemsamp & rtcontrib I obtain a
file with only the header and sometimes some weird symbols ike :
½7†7½7†7½7†7
If I use such file (*.dmx) with dctimestep I get the following Error
warning - unexpected data at the end of binary file
results/window_SOUTH.dmx
or
fatal - unexpected EOS reading results/window_SOUTH.dmx
my commands are just like in the Exercise 2 of the tutorial:
genklemsamp -vd 0 -1 0 objects/window_S.rad | rtcontrib -c 1000 -e MF:4 -f
reinhart.cal -b rbin -bn Nrbins -m sky_glow -faf model_dmx.oct >
results/south.dmx
If I try to do the same in Windows I get:
Usage: vwright {offset|name}
Argument "" isn't numeric in multiplication (*) at genklemsamp.pl line 51
Illegal division by zero at genklemsamp.pl line 51.
I'll really appreciate your help!
Thanks in advance!
Chantal.
Hi Chantal,
I'm not 100% sure, but I think you need to use ASCII data files under Windows, because it doesn't track the exact End-of-File, which confuses some programs. Replace the -faf option in rtcontrib (which should be rcontrib anyway) with -faa.
Date: September 25, 2013 10:21:28 AM PDT
Dear Radiance List
I'm coming with another question that is probably too simple but still keeps me from moving to the next phase of the 3Phase:
When I create the daylight matrix using genklemsamp & rtcontrib I obtain a file with only the header and sometimes some weird symbols ike : ½7†7½7†7½7†7
If I use such file (*.dmx) with dctimestep I get the following Error messages :
warning - unexpected data at the end of binary file results/window_SOUTH.dmx
or
genklemsamp -vd 0 -1 0 objects/window_S.rad | rtcontrib -c 1000 -e MF:4 -f reinhart.cal -b rbin -bn Nrbins -m sky_glow -faf model_dmx.oct > results/south.dmx
Thanks in advance!
Chantal.
Thanks a lot!! Indeed, after that correction I was able to create the
*dmx*for the south window orientation.
I take the opportunity to ask a simple question regarding *dctimestep*:
when I tried to use it for annual calculations with -n 8760 I get a msg:
Usage:dctimestep DCspec [ skyvec ]
dctimestep Vspec Tbsdf.xml Dmat.dat [ skyvec ]
I sounds to me that is not accepting the -n, so I guess that there might be
a new version that it takes it.
We have the 4.1 version released Nov 2011 installed in the server.
I wonder if the source file of that 'dctimestep new version' its available
somewhere the web to download?
Thanks in advance!
Chantal.
2013/9/25 Greg Ward <gregoryjward@gmail.com>
Hi Chantal,
*Date: *September 25, 2013 10:21:28 AM PDT
Dear Radiance List
½7†7½7†7½7†7
or
results/south.dmx
Thanks in advance!
Chantal.
Hi Chantal,
Yes, you need the newer version of dctimestep. You can find HEAD sources from the HTML interface at:
  http://www.radiance-online.org/cgi-bin/viewcvs.cgi/ray/src/#dirlist
Getting to the appropriate "Download" link you find:
  http://www.radiance-online.org/cgi-bin/viewcvs.cgi/ray/src/util/dctimestep.c?revision=2.27
Date: October 11, 2013 2:37:24 AM PDT
Thanks a lot!! Indeed, after that correction I was able to create the dmx for the south window orientation.
I take the opportunity to ask a simple question regarding dctimestep:
I sounds to me that is not accepting the -n, so I guess that there might be a new version that it takes it.
I wonder if the source file of that 'dctimestep new version' its available somewhere the web to download?
Thanks in advance!
Chantal.
Hi Chantal,
Dear Radiance List
or
Thanks in advance!
Chantal.
Thanks a lot Greg!! :slight_smile:
Ch.
2013/10/11 Greg Ward <gregoryjward@gmail.com>
Hi Chantal,
*Date: *October 11, 2013 2:37:24 AM PDT
Thanks a lot!! Indeed, after that correction I was able to create the *dmx
* for the south window orientation.
Thanks in advance!
Chantal.
Hi Chantal,
Dear Radiance List
½7†7½7†7½7†7
or
results/south.dmx
Thanks in advance!
Chantal.
