Three Phase Matrix Method using irradiance
In understanding Subramaniam paper “Daylighting simulations with radiance using matrix-based methods”, and his accompanying document (https://www.radiance-online.org/learning/tutorials/matrix-based-methods), I have a question related to rmtxop:
  • My gendaylitmtx parameters includes -O1 for output so should be total solar radiance rather than visible radiance
  • In rflixmtx parameters includes -I+ for irradiance contributions are reported
Therefore in the rmtxop step,
rmtxop -fa -c 1 1 1 /res.dat | rmtxop -t - | getinfo - > radiation.tab
To convert into a single column matrix should the -c parameter be -c 1 1 1 or -c 0.33 0.33 0.33?
My thoughts are -c 1 1 1 would be no scaling.
Some advice on the -c parameter would be appreciated when using irradiance rather than illuminance.
Regards
Terrance McMinn
Hi Terrance,
I feel like this question has been answered in another context, but I don’t remember where. Anyway, it is a bit confusing but the latest version of Radiance makes it easy with the “-c A” option, which is equivalent to “-c 0.33333 0.33333 0.33333” for an RGB input. You can check out the rmtxop man page for details. Your command can in fact be shortened to:
rmtxop -fa -c A res.dat -t | getinfo - > radiation.tab
Placing the -t at the end applies the transpose following any other operations, but since the only other operation is channel averaging, which isn’t affected by the transpose, the -t option could have also come before the input file name.
I hope this helps.
P.S. Sorry for the slow response - the discourse server was down and I am traveling.
Hello Greg,
Many thanks for your response.
In summary then, even when using irradiance input, you still need to use the -c 0.33333 0.33333 0.33333.
The 1/3rd factor in each of the RGB channels to nominally equal an overall factor of 1.
Regards
Terrance
Yes, you are always trying to come up with some kind of weighted average. If there’s a conversion factor as well (e.g., 179 lumens/watt) it’s best to think of that separately from the spectral averaging. RGB weights chosen usually arrive at photopic sensitivity, since that is the most commonly-used metric. There are of course others, such as scoptic and melanopic, which would use slightly different coefficients for R, G, and B. Spectral simulations with more than 3 channels still take the same approach, but with a longer list of weights.
Thank you Greg for clearing this up.
Regards
Terrance
