The curious case of the Ghost Luminaire
We've noticed some strange "ghost" luminaires in Radiance 4.2 (nothing to do with Halloween yesterday).
I've uploaded a file with a sample .pic file and the files used to generate it at http://upload.iesve.com/downloads/radiance_issues/ghost_luminaire.zip
As you can see from the .pic file there's a "ghost" luminaire to the centre left of the image which appears to be generated by the luminaire visible in the centre of the image (turning off the others while leaving it on still shows the ghost while vice-versa doesn't). Rotating the view to the right also removes the "ghost".
The commands we're running to generate the image are as follows:
oconv -f Monday.map Monday.rad > ghost_lum.oct
rpict -w -t 2 -vtv -vp 6.300 8.100 1.800 -vd -2.800 -3.600 0.000 -vu 0 0 1 -vh 80.000 -vv 60.000 -x 1600 -y 1600 -x 64 -y 64 -ps 6 -pt 0.100 -pj 1.0 -dj 0.350 -ds 0.300 -dt 0.250 -dc 0.350 -dr 2 -dp 128 -st 0.500 -ab 2 -aa 0.150 -ar 64 -ad 128 -as 64 -lr 6 -lw 0.005 -av 0.000 0.000 0.000 -af temp.amb ghost_lum.oct >amb.raw
rpict -w -t 2 -vtv -vp 6.300 8.100 1.800 -vd -2.800 -3.600 0.000 -vu 0 0 1 -vh 80.000 -vv 60.000 -x 1600 -y 1600 -ps 6 -pt 0.100 -pj 1.0 -dj 0.350 -ds 0.300 -dt 0.250 -dc 0.350 -dr 2 -dp 128 -st 0.500 -ab 2 -aa 0.150 -ar 64 -ad 128 -as 64 -lr 6 -lw 0.005 -av 0.000 0.000 0.000 -af temp.amb ghost_lum.oct >ghost_lum.raw
pfilt -m 0.25 -x /2 -y /2 ghost_lum.raw >ghost_lum.pic
If anyone has a few minutes to run this image on their systems & let me know if the "ghost" luminaire also appears for you it would be most appreciated (I'm using Radiance HEAD built from source on Windows 7 SP1).
Palbinder Sandher
Software Platform Engineer
T: +44 (0) 141 945 8500
F: +44 (0) 141 945 8501
http://www.iesve.com
**Design, Simulate + Innovate with the <Virtual Environment>**
Integrated Environmental Solutions Limited. Registered in Scotland No. SC151456
Registered Office - Helix Building, West Of Scotland Science Park, Glasgow G20 0SP
Email Disclaimer
Hi Pally,
I don't know who or what is setting your rendering parameters, but they are not something I would recommend. The "rad" program is a good way to get sane rendering options if you don't like the defaults. Setting -dt .25 -dc .35 is causing the strange contours around your light sources as well as numerous other inaccuracies. You are telling Radiance that you are fine with 25% error in the direct calculation, meaning everything else is worse.
The ghosts you are seeing are due most likely to a glazing surface that extends over your wall surface(s). I can't tell you for sure because the zip file you uploaded doesn't contain a complete model -- there are many referenced files that are missing.
What system are you using to assemble all this?
Date: November 1, 2012 9:15:20 AM PDT
Palbinder Sandher
Greg I'd completely forgotten about this issue & was reminded by a colleague recently as he was seeing this issue intermittently.
He's provided me an archive which I've uploaded to http://upload.iesve.com/downloads/radiance_issues/ghost_luminaire2.zip
It should contain - Monday.rad, Monday_mod.rad Luminaire Files - DULCET1203WW.* Parameter file - Monday.rdp (with -dt = 0.025 and -dc = 0.95) View file - Monday.rdv Octree file - image5.oct Pic file - image5.pic (with ghost luminaire)
We're running on Windows 7 x64. The radiance code I used to build from source is a few months old (mid-September IIRC) as I haven't had time to re-download & re-run Cmake etc. if there's been any updates since then.
Palbinder Sandher
Email Disclaimer
Sent: 01 November 2012 16:33
To: code development
Subject: Re: [Radiance-dev] The curious case of the Ghost Luminaire
Hi Pally,
Palbinder Sandher
Radiance-dev mailing list
I can't really tell what's going on because I can't reproduce your strange image with the ghost luminaire. The ghost doesn't even match the appearance of the luminaires you've defined, so it makes no sense to me.
You should retry with the latest HEAD version to see if it's still happening for you. If it is, then we have an issue I can investigate further.
Date: February 13, 2013 7:40:44 AM PST
Palbinder Sandher
Email Disclaimer
Hi Pally,
Palbinder Sandher
Greg I'm using the snapshot from http://public.kitware.com/gitweb?p=radiance.git;a=tree which doesn't appear to have been changed since the 15th of September. http://radiance-online.org/cgi-bin/viewcvs.cgi/?pathrev=MAIN doesn't appear to have tarball generation enabled.
Palbinder Sandher
Email Disclaimer
Sent: 13 February 2013 19:14
Palbinder Sandher
Email Disclaimer
Hi Pally,
Palbinder Sandher
Pally,
I just ran your model on a LINUX box. Here is some extra info and
additional steps that were required:
$ getinfo image5.oct
image5.oct:
  #?RADIANCE
  FORMAT=Radiance_octree
$ getinfo image5.pic
image5.pic:
  #?RADIANCE
  OCTREE=image5.oct
  rpict -w -t 5 -vtv -vp 6.300 8.100 1.800 -vd -2.800 -3.600 0.000 -vu
0 0 1 -vh 80.000 -vv 60.000 -x 1600 -y 1600 -ps 5 -pt 0.075 -pj 1.0
-dj 0.600 -ds 0.200 -dt 0.025 -dc 0.950 -dr 3 -dp 256 -st 0.300 -ab 2
-aa 0.100 -ar 256 -ad 512 -as 256 -lr 8 -lw 0.002 -av 0.000 0.000
0.000 -e Radiance.log -af temp.amb
  SOFTWARE= RADIANCE 4.2a built by Integrated Environmental Solutions
Limited. (September 2012)
  VIEW= -vtv -vp 6.3 8.1 1.8 -vd -2.8 -3.6 0 -vu 0 0 1 -vh 80 -vv 60
-vo 0 -va 0 -vs 0 -vl 0
  CAPDATE= 2012:11:02 12:18:35
  GMT= 2012:11:02 12:18:35
  FORMAT=32-bit_rle_rgbe
  EXPOSURE=3.934435e+000
gvim Monday\.rad \(paths\) gvim Monday.rdv (prepend 'rvu')
$ cat Monday.rdp
-ps 5 -pt 0.075 -pj 1.0 -dj 0.600 -ds 0.200 -dt 0.025 -dc 0.950 -dr 3
-dp 256 -st 0.300 -ab 2 -aa 0.100 -ar 256 -ad 512 -as 256 -lr 8 -lw
0.002 -av 0.000 0.000 0.000 -e Radiance.log
$ oconv Monday.map Monday.rad > Monday.oct
Test a) - With opts file Monday.rdp
rpict \-vf Monday\.rdv @Monday\.rdp Monday\.oct &gt; axel\.hdr Test b\) \- With opts from image5\.pic rpict -w -t 5 -vtv -vp 6.300 8.100 1.800 -vd -2.800 -3.600 0.000 -vu
0 0 1 -vh 80.000 -vv 60.000 -ps 5 -pt 0.075 -pj 1.0 -dj 0.600 -ds
0.200 -dt 0.025 -dc 0.950 -dr 3 -dp 256 -st 0.300 -ab 2 -aa 0.100 -ar
256 -ad 512 -as 256 -lr 8 -lw 0.002 -av 0.000 0.000 0.000 Monday.oct >
image5_axel.hdr
Both images (image5_axel.hdr and axel.hdr) don't show the ghost
luminaires that you have in image5.pic. No idea what's going on.
I also inspected your model in Rhino3d. The surfaces that IESVE
generated can be a bit weird, especially when you don't enable 'inner
volumes'. In your case, the walls at least are good, with no co-planar
surfaces.
Cheers
Axel
Palbinder Sandher
Email Disclaimer
Palbinder Sandher
Email Disclaimer
Hi Pally,
Palbinder Sandher
Perhaps this link can help:
  http://ghostbusters.en.softonic.com/
It's supposed to work on Windows, but maybe it will work for luminaires, too.
Sent from my iPad
On Feb 14, 2013, at 8:33 AM, Axel Jacobs <[email protected]> wrote:
Pally,
image5.oct:
   #?RADIANCE
image5.pic:
   #?RADIANCE
   OCTREE=image5.oct
$ cat Monday.rdp
image5_axel.hdr
surfaces.
Cheers
Axel
Palbinder Sandher
Email Disclaimer
Palbinder Sandher
Email Disclaimer
Hi Pally,
Palbinder Sandher
(I posted earlier from my personal address, but I don't think I'm actually
subscribed from that one. Apologies if this ends up showing up 2x...)
Hi Pally,
I can help here. The origin trunk (i.e. "master") on that Kitware git repo
does not refresh the way you might think. Kitware has a “combined”
branch that actually has the latest HEAD (updated nightly, I believe at
midnight EST). To add this, issue:
"git checkout -t origin/combined"
"git branch" will tell where you are, and what you've got checked out:
hooper:radiance rpg$ git branch
combined
* master
You can switch between branches with the 'checkout' command:
hooper:radiance rpg$ git checkout combined
Switched to branch 'combined'
* combined
master
I work off this combined branch for building current packages (speaking of
which a fresh set of them should go live on the NREL site today). I know
this is confusing, but this is a vestige from when Kitware was doing all
the heavy lifting getting the CMake build system implemented across the
source tree, and making frequent changes.
Anyhow, the takeaway here is if you wish to use the Kitware git repo for
your latest HEAD source, use the combined branch for now!
P.S.
I know this is a bit confusing. We will hopefully set up our own (NREL)
git mirror that I'll be able to refresh whenever I need to.
Rob Guglielmetti
Golden, CO 80401
303.275.4319
Palbinder Sandher
SC151456
Glasgow G20 0SP
Email Disclaimer
further.
Palbinder Sandher
SC151456
Glasgow G20 0SP
Email Disclaimer
Hi Pally,
else is worse.
generate it at
SP1).
Palbinder Sandher
Ah ok I'll try rebuilding using a snapshot of the combined branch & see how I get on.
Palbinder Sandher
Email Disclaimer
Sent: 15 February 2013 02:04
(I posted earlier from my personal address, but I don't think I'm actually subscribed from that one. Apologies if this ends up showing up 2x...)
Hi Pally,
I can help here. The origin trunk (i.e. "master") on that Kitware git repo does not refresh the way you might think. Kitware has a “combined” branch that actually has the latest HEAD (updated nightly, I believe at midnight EST). To add this, issue:
combined
* master
hooper:radiance rpg$ git checkout combined Switched to branch 'combined'
* combined
master
I work off this combined branch for building current packages (speaking of which a fresh set of them should go live on the NREL site today). I know this is confusing, but this is a vestige from when Kitware was doing all the heavy lifting getting the CMake build system implemented across the source tree, and making frequent changes.
Anyhow, the takeaway here is if you wish to use the Kitware git repo for your latest HEAD source, use the combined branch for now!
P.S.
I know this is a bit confusing. We will hopefully set up our own (NREL) git mirror that I'll be able to refresh whenever I need to.
Rob Guglielmetti
National Renewable Energy Laboratory (NREL) Commercial Buildings Research Group
Golden, CO 80401
303.275.4319
Palbinder Sandher
SC151456
Glasgow G20 0SP Email Disclaimer
further.
Palbinder Sandher
SC151456
Hi Pally,
Setting -dt
generate it at
oconv -f Monday.map Monday.rad > ghost_lum.oct rpict -w -t 2 -vtv
0.000
0.000 -af temp.amb ghost_lum.oct >amb.raw rpict -w -t 2 -vtv -vp
temp.amb ghost_lum.oct >ghost_lum.raw pfilt -m 0.25 -x /2 -y /2
Windows 7 SP1).
Palbinder Sandher
