Texture path in mesh file
Hi,
I have a mesh file that I created with obj2mesh and the “-a” option for specifying a texture using “colorpict”. However I find that I can only use this mesh file if the texture file is specified using an absolute path in “colorpict”. The problem with that is that I can’t move this file around, even if I move the texture along with it. Is there any solution to that?
Thanks
