Dear List,
I was trying to simulate the visual appearance of brushed alluminum, but
I am struggling with the roughness of the materials.
I am using metal and metal2 at different roughness settings, but I
always seem to get a pattern in the roughness of the material, I was
wondering if any other rpict parameters affect the material behaviour.
My current suspects are:
-ad Set the number of ambient divisions to N
-as Set the number of ambient super-samples to N
-ms Set the medium sampling distance to sampdist
does anybody has some insight in this?
Giovanni
Giovanni Betti
Hi Giovanni,
Set "-u+" to turn on random Monte Carlo sampling if the pattern bothers you. You'll get a noisier image, but without the brushed look of the low discrepancy sequence rpict normally uses.
From: "Giovanni Betti" <gbetti@fosterandpartners.com>
Date: July 12, 2011 11:43:02 AM PDT
Dear List,
Giovanni
Hi Giovanni,
I think that what you need to look at is actually specular jitter and threshold (-sj and -st), -ms is for something unrelated assuming I remember correctly.
Another factor that can contribute to the appearance of a "pattern" (sort of striated) in material with specular and roughness components is that fact that Radiance use pseudo random sampling. One way to make this go away (albeit at some expense in terms of compute time as well as requiring higher image oversampling) is to use the -u switch for uncorrelated monte carlo sampling.
# Jack de Valpine
On 7/12/2011 2:43 PM, Giovanni Betti wrote:
Dear List,
Giovanni
Giovanni Betti
Thanks Jack and Greg,
I am trying this right now,
Will let you know how it works, once the rendering completes!
G
Sent: 12 July 2011 19:54
Subject: Re: [Radiance-general] Surfaces Roughness and simulation
parameters
Hi Giovanni,
Dear List,
but
Giovanni
