Dear Group
Does anyone here know how to alter or adjust gensky's sun color? I guess what I am looking for is a color that is warmer that the color that I am achieving now. This is for asthetic purposes but I want a solution that is physically accurate. I have tried altering the day and time of day to achieve this but it seems that only the angle, height, and intensity of the sunlight is changed and not the color. I don't mind hard coding it in the application if it necessasary if it isn't too messy. Any suggestions?
Marcus
Hi Marcus,
This can be done with an appropriate insertion of rcalc in your Radiance command. In the scene file, you would modify your gensky line to read:
!gensky 6 21 12 | rcalc -p -i sunlight.fmt \
-e 'sr=1.035*si;sg=1.003*si;sb=0.826*si' \
-o 'void light solar 0 0 3 \{sr\} {sg} ${sb}'
The color for the sun is converted from the CIE (x,y) chromaticity for standard illuminant B, which is (0.3485,0.3517). The file "sunlight.fmt" must contain the following:
void light solar
3 \{si\} {si} ${si}
You'll need the latest version of rcalc (3.6.1 release), as previous versions did not have the -p option.
Hope this works for you.
Date: January 6, 2005 8:00:39 AM PST
Dear Group
Marcus
Here is tcl code to convert the sun color from a blackbody temperature "T" to Radiance RGB:
# input =
proc Kelvin_to_sun_RGB {T YL solar_radiance} {
# converts a color temperature of degrees Kelvin into RGB
# given: color temp. T and the luminance YL of the source
# convert the blackbody temperature T into "RGB"
# Both fits have R^2= 1.000 over the range from 2000K
# to 11000K. Both look ill behaved above 11000K
set x [expr 0.8405 - 2.1783*pow(10,-4) *$T \
+ 3.5254*pow(10,-8) *$T*$T \
- 2.7046*pow(10,-12)*$T*$T*$T \
+ 7.9696*pow(10,-17)*$T*$T*$T*$T]
set y [expr 0.30587 + 1.3655*pow(10,-4) *$T \
- 5.6154*pow(10,-8) *$T*$T \
+ 8.9484*pow(10,-12)*$T*$T*$T \
- 6.5352*pow(10,-16)*$T*$T*$T*$T \
+ 1.8158*pow(10,-20)*$T*$T*$T*$T*$T]
set z [expr 1.00000000 -$x-$y]
set X [expr $x*$YL/$y]
set Z [expr $z*$YL/$y]
# X, YL, Z are the spectral tristimulus values
# the following formulae assume the monitor alignments given in the book :
# "procedural elements for computer graphics" by David F. Rogers, 1985 McGraw-Hill; pp. 397
set R [expr 2.739*$X - 1.145*$YL - 0.424*$Z]
set G [expr -1.119*$X + 2.029*$YL + 0.033*$Z]
set B [expr 0.138 *$X - 0.333*$YL + 1.105*$Z]
if {$B<0} {set B 0.0}
set k1 [expr (0.3*$R+0.59*$G+0.11*$B)]
# fact*k1=solar$radiance; correct RGB to actual values given in "void light solar"
# from the gensky output
set fact [expr $solar_radiance/$k1]
set R [expr $R*$fact]; set G [expr $G*$fact]; set B [expr $B*$fact]
return "$R $G $B"
_______________________________________________________________________
Martin Moeck, Penn State
Sent: Thu 1/6/2005 11:00 AM
To: [email protected]
Cc:
Subject: [Radiance-general] Sun Color
Dear Group
Marcus
Thanks Martin and Greg for the help for my question about the sun color.
I have done some light research on of the sun's color temperature. I think Martin's may be the method that I would prefer in converting a color temperature and luminance of the sun to the RGB used with the light primative. I have had some problems running the script. In a comment line it states:
converts a color temperature of degrees Kelvin into RGB given: color temp. T and the luminance YL of the source
My problem is that this script takes three variables (T, YL, and solar_radiance) but the comment only mentions two variables (T and YL). What is the solar_radiance and how does it differ from the luminance of the source (the source I am assuming is the sun)? Also, what are the units of measurement for the 3 variables? Do you have an example for this?
Thanks
Marcus Jacobs
I modified the script.Use it as follows:
# generate a radiance sun: gensky 3 21 8
void light solar
3 5.18e+006 5.18e+006 5.18e+006
YL=179*(5.18e+006 *.265+5.18e+006 *.67+5.18e+006*.0648)= 927034556
proc Kelvin_to_sun_RGB {T YL} {
set x [expr 0.8405 - 2.17834e-04 *$T \
+ 3.52544e-08 *$T*$T \
- 2.7046e-12*$T*$T*$T \
+ 7.9696e-17*$T*$T*$T*$T]
set y [expr 0.30587 + 1.3655e-4 *$T \
- 5.6154e-8 *$T*$T \
+ 8.9484e-12*$T*$T*$T \
- 6.5352e-16*$T*$T*$T*$T \
+ 1.8158e-20*$T*$T*$T*$T*$T]
set z [expr 1.0-$x-$y]
return "$R $G $B"
Kelvin_to_sun_RGB 2100.0 $YL
# a sun with a color temperature of 2100 K and a luminance of YL
void light solar
0 0 3
2017646607 601412803 19892974
The script does not work for very low sun angles, as the sun changes to pink orange, which cannot be represented by a blackbody. Use some filter colors from Lee or Rosco for that.
Martin Moeck
Sent: Fri 1/7/2005 8:10 PM
Cc:
Subject: [Radiance-general] RE: Sun Color
states:
Thanks
Marcus Jacobs
