Hi Francesco,
dear folk,
I have been in some discussions with a user about gendaylit and especially the cygwin- binary of it.
We found out, that the subtended angle of the sun differs from the original gendaylit (0.533) version to the one, which we can download on http://www.bozzograo.net/radiance(0.5 for cygwin binary).
For that reason, I checked in one of the main references in the solar world (Duffie, Beckman: Solar engineering of thermal processes) and found 32' for the subtended solar angle, which corresponds to 0.5333.
So I assume you changed the value in the source code, or? But as long as you are not adapting the radiance value of the light source (which you don't do), you'll loose more than 10% of the flux of the sun by reducing the value from 0.533 to 0.5 !!
Is there any reason to use 0.5 instead of 0.533?
And a question to Greg: gensky is also using 0.5. Is there any reference to that? But: As long as the overall flux is correct, the difference in the angle can be neglected.
For the cygwin-version of gendaylit I would suggest to correct that value in your version to 0.533 of the source code. In addition to this, I'll try to put a gendaylit version on our Web-page, which can be compiled also under cygwin without any modification. If ready, I'll announce this here again.
Jan
Dipl.-Ing. Jan Wienold
Project Manager
Fraunhofer-Institut f�r Solare Energiesysteme
Thermal Systems and Buildings, Lighting and Daylighting
Phone: +49(0)761 4588 5133 Fax:+49(0)761 4588 9133
In office: Mo,Tue: 9:00-18:00
We-Fr: 8:30-14:00
