Dear Thomas,
Su2rad seems to miss “convert.exe”, which doesn’t appear in the SketchUp folder even after the reinstallation of the plugin. Below you can find the report from the Ruby console.
It would be great if you knew how to fix the problem. Thank you for your help!
RunTimeConfig.initialize()
RunTimeConfig: initPaths() ...
searching 'replmarks.exe' ...
=> found 'replmarks.exe' in 'C:/Users/ilkkrola/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/su2radlib/bin/WIN'
searching 'convert.exe' ...
... skipping system folder 'C:\Windows\system32'
... skipping system folder 'C:\Windows\System32\Wbem'
... skipping system folder 'C:\Windows\System32\WindowsPowerShell\v1.0\'
=> application 'convert.exe' not found
searching 'ra_ppm.exe' ...
=> found 'ra_ppm.exe' in 'C:/Users/ilkkrola/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/su2radlib/bin/WIN'
searching 'obj2mesh.exe' ...
=> found 'obj2mesh.exe' in 'C:/Users/ilkkrola/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/su2radlib/bin/WIN'
WARNING: path for CONVERT does not exist ('')
### su2rad.rb export ###
searching in 'C:/Users/ilkkrola/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/su2radlib/ray'
130 materials in file 'C:/Users/ilkkrola/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/su2radlib/ray/K_and_E.rad'
69 materials in file 'C:/Users/ilkkrola/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/su2radlib/ray/materials.rad'
33 materials in file 'C:/Users/ilkkrola/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/su2radlib/ray/ral.rad'
=> materials total: 232
plastic: 212
metal: 4
glass: 12
texfunc: 2
brightfunc: 1
alias: 1
[W] 'convert' not found => disabling 'textures' options
### finished: 2016-04-20 17:27:48 +0200 ###
### status: running (groups=0, faces=7) ###
untitled1.zip (108 KB)
Von: Thomas Bleicher [mailto:[email protected]]
Gesendet: Mittwoch, 20. April 2016 03:58
An: Radiance general discussion
Betreff: Re: [Radiance-general] su2rad export problem
Hi
I just tried it with SketchUp Make 2016 on a Windows 10 system. I'm pretty sure there isn't a general problem with Windows 7 or I'd have heard about it by now.
Can you try to export again with the Ruby console window open, please? There should be some information when the script starts and especially when there is an error. Please copy the output and send it over.
On Tue, Apr 19, 2016 at 7:27 AM, Ma <[email protected] <mailto:[email protected]> > wrote:
Dear Thomas,
unfortunately it doesn’t help. I’ve already tried it out with SketchUp Make 2015 and 2016. Could there possibly be any problem with the “Make” version or with my Windows version? I use Windows 7 Enterprise Service Pack 1 (64-bit). I would be grateful for any hint.
Best regards,
Marzena
Von: Thomas Bleicher [mailto:[email protected] <mailto:[email protected]> ]
Gesendet: Sonntag, 17. April 2016 15:16
Cc: DAYSIM discussion
Hi Marzena
Please update to the latest release su2rad_2014.0.0. This should fix the problem. You can download it via the link below:
https://www.dropbox.com/s/pewocv4df0i2i05/su2rad_2014.0.0.rbz
On Fri, Apr 15, 2016 at 4:40 AM, Marzena Husser <[email protected] <mailto:[email protected]> > wrote:
I have a problem with su2rad. I am using SketchUp Make 2015 and su2rad_daysim_r03. Unfortunately, the export doesn’t work, neither by colour/layer nor by “daysim”.
Exports by colour and by layer generate the .rif file and a few directories, but as I try to import it into daysim, the following error message appears:
“Cannot find files:
…\radiance\medium
…\radiance\ambfiles\untitled1.amb
…\1)”
Export by “daysim” doesn’t work at all. The following error message appears:
“Error reading file: prefs.dat”
Moreover, the material assignment doesn’t work as well. It’s impossible to drop the radiance materials over the SketchUp elements.
Can anybody help me? I would really appreciate it.
Weidenmeise
