If you have any tendency to share files between platforms check that you
haven't saved your file in a Windows format, where the line ending
characters are saved differently than a Unix type environment where you
may be running your script. If you work on scripts under windows at all
some good programming text editors like Notepad++ have an explicit menu
option to convert between Win/Mac/Unix formats.
[mailto:[email protected]] On Behalf Of Per
Haugaard
Sent: Thursday, October 08, 2009 8:04 AM
To: Radiance Radiance
Subject: [Radiance-general] Strange filetype naming when redering
withradiance
Dear users,
I hope this is the correct forum to post this question.
I have run stumble upon a strange problem rendering images with
radiance.
I have made a simple file containing the different commands to be
executed to render the images/data needed. When I execute this file
(source xxx.cal) All the output files have a (?) added to the file type
(e.g. grid.xyz? instead of grid.xyz). Furthermore I cannot use \ as line
separation in my file anymore.
Does anyone have any experience with these types of errors?
Best regards
Per Haugaard
