Dear Lars, Jack and users,
I use the bash shell in Ubuntu.
Here is my simple scripting:
## Level 4
## make an illuminumce picture of the plane
cat grids/level_4.xyz | rtrace -I -ab 4 -aa 0.05 -ar 128 -ad 512 -as 256 -x 759 -y 1160 -af ambfiles/df.amb -fac octrees/sav55_DF_LT70-60.oct > images/grid2illum_level_4.pic
## Decrease the size of the picture
pfilt -1 -x /10 -y /10 images/grid2illum_level_4.pic > images/grid2illum_level_4_resized.pic
## calculate the daylight factor for the picture grid2illum_resized.pic
pcomb -e 'lo=li(1)/le(1)/10000*100' images/grid2illum_level_4_resized.pic > images/grid2illum_level_4_resized_df.pic
## falsecolor for the daylight factor picture grid2illum_resized_df.pic
falsecolor -i images/grid2illum_level_4_resized_df.pic -s 11 -n 5.5 -l "DF %" > images/grid2illum_level_4_resized_df_falsecolor.pic
## rm -f images/grid2illum_level_4.pic images/grid2illum_level_4_resized.pic
As mentioned in my prior mail the output of the first command is grid2illum_level_4.pic?
Any ideas? This does not happen when I enter other similar projects.
Best regards
Per
--- Den tors 8/10/09 skrev Jack de Valpine <[email protected]>:
Fra: Jack de Valpine <[email protected]>
Emne: Re: [Radiance-general] Strange filetype naming when redering with radiance
Til: [email protected], "Radiance general discussion" <[email protected]>
Dato: torsdag 8. oktober 2009 15.17
Hi Per,
Can you post the contents of your shell script? That way people might
be able to provide more input.
-Jack de Valpine
Per Haugaard wrote:
Dear users,
I hope this is the correct forum to post this question.
I have run stumble upon a strange problem rendering images with
radiance.
I have made a simple file containing the different commands to be
executed to render the images/data needed. When I execute this file
(source xxx.cal) All the output files have a (?) added to the file type
(e.g. grid..xyz? instead of grid.xyz). Furthermore I cannot use \ as
line separation in my file anymore.
Does anyone have any experience with these types of errors?
Best regards
Per Haugaard
Få en billig laptop. Se Kelkoos gode tilbud her!
# Jack de Valpine
Trænger du til at se det store billede? Kelkoo giver dig gode tilbud på LCD TV! Se her http://dk.yahoo.com/r/pat/lcd
