strange error massage from genBSDF
Hello list,
I have just recompiled Radiance because I was getting little bit strange
results when using Three-phase method, and I was not sure if I am using most
updated version.
I have downloaded fresh version and when I recompiled Radaince and run the
scripts again I have got this error when running genBSDF command.
xform: cannot find file "geometry/BSDF_old_open.rad"
Could not load Radiance input
command is:
genBSDF -c 1000 -r '-st 0.0001' +forward -backward -geom -dim 0 1.98 0 1.13
-0.01 0 geometry/BSDF_old_open.rad> results/xml/BSDF_old_open_down.xml
The file and folder are there and it was running correctly before.
Does anyone has any suggestions how to solve this?
Thank you very much for your help.
David
Hi David,
I assume you've done the obvious and made sure the file "geometry/BSDF_old_open.rad" exists and is readable. Try issuing the command with "./geometry/BSDF_old_open.rad" instead and see if that works. If it does, that means that your RAYPATH environment variable doesn't include the current working directory ('.') as part of the search. This normally goes in front, e.g., "RAYPATH=.:/usr/local/lib/ray".
The xform command is special in that it searches the RAYPATH directories rather than taking file names you give it literally. This simplifies creating a library of often-used objects, but can be confusing in other contexts.
Date: May 12, 2011 8:50:22 PM PDT
Hello list,
I have just recompiled Radiance because I was getting little bit strange results when using Three-phase method, and I was not sure if I am using most updated version.
I have downloaded fresh version and when I recompiled Radaince and run the scripts again I have got this error when running genBSDF command.
command is:
genBSDF -c 1000 -r '-st 0.0001' +forward -backward -geom -dim 0 1.98 0 1.13 -0.01 0 geometry/BSDF_old_open.rad> results/xml/BSDF_old_open_down.xml
David
Hello Grag,
thank you, it is working now. You were right all usual.
David
On 12 May 2011 21:02, Greg Ward <[email protected]> wrote:
Hi David,
contexts.
> From: David Appelfeld <[email protected]>
> Hello list,
updated version.
> command is:
> David
