Strange behaviour with mixed material
Dear all,
I'm trying to define a mixfunc material to modify a mirror definition, so I can create holes (horizontal bands in this case) in the mirror. This was explained in an old tutorial by G. Antonutto, which now seems lost (at least I couldn't find it online... pillo?).
The complete definition is like this:
## metal
void metal metal_01
5 .8 .8 .8 .05 0
## mix the metal with void to create holes
void mixfunc strip
4 metal_01 void 'if(sin(Pz/10),0,1)' .
## alter the reflectance of mirror, reflectance is 0% for holes
void brightfunc band
2 'if(sin(Pz/10),0,1)' .
## mirror attached to the metal surface with holes
band mirror mix_01
1 strip
3 .9 .9 .9
If I create a cube with the "mix_01" material, it looks as expected. Horizontal bands of void in the mirror let the direct light through and the reflected light is also in matching stripes.
However, with the diffuse calculation, light doesn't seem to get through the void part. For example, if I measure irradiance inside the cube with only a glow source outside, I get zero.
The strangest part is that if I look at the model in rvu, it looks fine and there is diffuse light inside... unless I set -aa 0!!!
All other settings seem to make no difference (with ab > 0, of course).
Rpict behaves like rtrace, no diffuse light through.
I've tried setting all rtrace parameters to the rvu defaults (including dr 0), but the result is still nothing.
I'm sure there is an explanation, which is possibly that the material is just too weird, but I'm still confused by the strange difference in behaviour between rtrace/rpict and rvu...
Any ideas?
Thanks!
Santiago
Hi Santiago,
Giulio kindly shared his tutorials and I haven't gotten around to putting them onto radiance-online.org, mostly because I don't know how to modify the website anymore since it was updated. However, I have uploaded this particular tutorial for you to:
  http://www.anyhere.com/gward/pickup/giulio_mirror.tar.gz
However, this is really a situation that didn't occur to me, where you have indirect rays coming from the opposite side. I see now that I should modify a test in the m_mirror.c routine to account for this case. I will send you a modified version of this file in hopes that you can rebuild and test it for me.
Date: June 3, 2016 1:10:50 PM PDT
Dear all,
I’m trying to define a mixfunc material to modify a mirror definition, so I can create holes (horizontal bands in this case) in the mirror. This was explained in an old tutorial by G. Antonutto, which now seems lost (at least I couldn’t find it online… pillo?).
## metal
void metal metal_01
5 .8 .8 .8 .05 0
void mixfunc strip
band mirror mix_01
1 strip
3 .9 .9 .9
If I create a cube with the “mix_01” material, it looks as expected. Horizontal bands of void in the mirror let the direct light through and the reflected light is also in matching stripes.
However, with the diffuse calculation, light doesn’t seem to get through the void part. For example, if I measure irradiance inside the cube with only a glow source outside, I get zero.
The strangest part is that if I look at the model in rvu, it looks fine and there is diffuse light inside… unless I set –aa 0!!!
I’ve tried setting all rtrace parameters to the rvu defaults (including dr 0), but the result is still nothing.
I’m sure there is an explanation, which is possibly that the material is just too weird, but I’m still confused by the strange difference in behaviour between rtrace/rpict and rvu…
Any ideas?
Thanks!
Santiago
Just a quick follow-up. This was indeed a bug in the m_mirror routine, which is now sorted out. The next distribution should fix it.
Thanks, Santiago!
Date: June 3, 2016 1:38:53 PM PDT
Hi Santiago,
Dear all,
## metal
void metal metal_01
5 .8 .8 .8 .05 0
void mixfunc strip
band mirror mix_01
1 strip
3 .9 .9 .9
Any ideas?
Thanks!
Santiago
Thanks due to Kanae Hagiwara, from our Tokyo office, who found the problem!
And to Greg, of course, for finding the solution!
S.
Sent: 06 June 2016 17:25
To: Greg Ward
Cc: Radiance general discussion
Subject: Re: [Radiance-general] Strange behaviour with mixed material
Thanks, Santiago!
From: Greg Ward <[email protected]<mailto:[email protected]>>
Hi Santiago,
Giulio kindly shared his tutorials and I haven't gotten around to putting them onto radiance-online.org<http://radiance-online.org>, mostly because I don't know how to modify the website anymore since it was updated. However, I have uploaded this particular tutorial for you to:
From: Santiago Torres <[email protected]<mailto:[email protected]>>
Dear all,
## metal
void metal metal_01
5 .8 .8 .8 .05 0
void mixfunc strip
band mirror mix_01
1 strip
3 .9 .9 .9
Any ideas?
Thanks!
Santiago
I've put up the "Asphalt" example at
http://www.radiance-online.org/learning/tips-tricks/Asphalt\. Please let me
know if it looks OK.
Randolph
S.
*Sent:* 06 June 2016 17:25
*To:* Greg Ward
*Cc:* Radiance general discussion
*Subject:* Re: [Radiance-general] Strange behaviour with mixed material
Thanks, Santiago!
*Date: *June 3, 2016 1:38:53 PM PDT
Hi Santiago,
test it for me.
*Date: *June 3, 2016 1:10:50 PM PDT
Dear all,
## metal
void metal metal_01
5 .8 .8 .8 .05 0
void mixfunc strip
band mirror mix_01
1 strip
3 .9 .9 .9
Any ideas?
Thanks!
Santiago
