strange artifacts in rendering (and Yosemite bug)
As it turns out, this appears *not* to be a problem with Yosemite after all, but an issue with the last official release (4.2.2), whose accuracy isn't quite as good as the latest (HEAD or 5.0a) with respect to its Hessian interpolation method. The artifacts MJ noticed were due to inaccuracies in the interreflection calculation, for which this scene is something of a worst case. Decreasing the -aa parameter while increasing -ad seems to resolve these issues, especially with the latest code.
While playing around with Yosemite trying to reproduce these artifacts, I discovered that the problems I thought I was having with the system select() call were in fact due to a bug in the way Yosemite handles application-level file locking. This was a complete surprise, but it turns out not to be so difficult to work around.
Without getting too much into the details, the stdio library has these lock/unlock calls to make the library thread-safe, which of course I don't care about because I don't use threads, but they severely impact performance even on unthreaded code. In some cases, it requires a mutex lock/block/unlock procedure for every character that is input or output, completely defeating the purpose of i/o buffering that is the purpose of stdio in the first place. Therefore, I had some workarounds in place to reduce or eliminate this overhead, basically locking the files once at the outset to avoid the per-call mutex overhead.
This all worked fine up until the latest release of Mac OS X (10.10), when Apple changed the behavior of fork() such that it preserves application-level i/o locking for no conceivable reason. Since these locks are designed to negotiate between threads sharing memory (i/o buffers), and separate processes don't share memory, the locks should sever on fork(). Every Unix out there does this, except Mac OS X 10.10.x. Therefore, when I made a call to flockfile() at the start of rvu or rtrace, then forked its children, each child would deadlock the instant it tried to use a shared file pointer (i.e., the ambient file).
You could say I was being cavalier about the use of flockfile(), but I was just trying to work around a horrible performance bottleneck introduced with automatic application-level locking in stdio. It's one thing to introduce a new feature and suggest that people using multi-threading take advantage of it. It's another thing to implement locking as the new default behavior, while decreasing i/o performance by about 90% (no exaggeration) even when it is not needed, then not even offer a means to disable it.
In any event, I checked in a change that I'm hoping fixes this issue under Yosemite, while not costing us too much on all the other Unix platforms that don't have this issue.
Subject: Fwd: [Radiance-general] strange artifacts in rendering
Date: August 20, 2015 9:14:23 AM PDT
Just forwarding this to the mailing list in case as an additional warning against installing Mac OS X Yosemite (10.10.x). As if the multi-processing bug were not enough, there seem to be other problems with instances and/or textures (not sure) on that platform.
I may try investigating this on the weekend, but I don't hold out much hope for a resolution.
Subject: Re: [Radiance-general] strange artifacts in rendering
Date: August 19, 2015 4:58:24 PM PDT
To: "Gregory J. Ward" <[email protected]>
I think the problem might indeed be with OS 10.10. None of the 20 scenes that I rendered on OS 10.9 had any issues, whereas more than half of the 20 on OS 10.10 did. Please see attached files for examples.
Thanks for your help!
MJ
On Wed, Aug 19, 2015 at 4:33 PM, Minjung Kim <[email protected]> wrote:
I'm going to render a bunch of other blobby objects on 10.9, and see if I get the problem here. I'll let you know what I find out.
Thanks!
MJ
On Wed, Aug 19, 2015 at 4:30 PM, Gregory J. Ward <[email protected]> wrote:
Thanks, Minjung.
I guess we can add this to the list of bugs under Mac OS X 10.10, which to me has been a disastrous release. I seriously doubt I will be able to fix problems on this platform, but I'll give it a try when I have some time.
Date: August 19, 2015 4:16:50 PM EDT
Thanks for your help! I am still unable to get the artifacts to come back -- but only on my current machine (late-2013 iMac, 21.5 in., OS X 10.9). If I run the same code on a different machine (late-2013 iMac, 21.5 in., OS X 10.10), I reliably get the artifact. Isn't that strange?
Attached are the files that I used. To run, please use the following commands:
oconv square.rad > square.oct
oconv scene.rad > scene.oct
rpict -x 1024 -y 1024 -vh 12.018 -vv 12.018 -vp 0 -0.57 0 -vd 0 1 0 -vu 0 0 1 -av 0 0 0 -vtv -ab 1 scene.oct > scene.pic
pfilt -1 -x 512 -y 512 -e 1 -r 0.6 scene.pic > scene.hdr
In scene.rad, the square is incorporated as an instance. I know that I don't really need to instance the square since I only have one, but the scene with the artifacts was using instances, so I thought it would be better to send you the code as is.
If anything is unclear, please let me know. Thanks again!
MJ
On Tue, Aug 18, 2015 at 7:00 PM, Minjung Kim <[email protected]> wrote:
Thanks! I'm putting together the files, but I'm unable to replicate the problem using my latest code, though I don't think I've changed anything substantial. I'll get back to you once I can reliably replicate the artifacts.
MJ
On Mon, Aug 17, 2015 at 9:04 PM, Greg Ward <[email protected]> wrote:
Hi MJ,
Can you send me your model & rendering parameters off-list. I won't know what's going on until I play with it.
Subject: [Radiance-general] strange artifacts in rendering
Date: August 17, 2015 5:30:37 PM EDT
Hi everyone,
I am getting strange artifacts in my renderings, and am wondering which parameters to tweak in order to get rid of them. The artifacts look like a white, or sometimes half-black and half-white, patch at random locations. See below for examples:
http://minjung.ca/tmp/artifacts1.png
http://minjung.ca/tmp/artifacts2.png
I've tried (1) setting ad = 4096, as = 1024, and (2) setting aa = 0, ar = 0, but neither of these two settings fixed the problem. Do you have any idea what might be happening? Here are some possibly relevant factors:
- The object is completely Lambertian.
- The only light source in the scene is a glow source that is positioned behind the camera, and covers as much of the sky as possible.
- I don't think I've ever encountered such artifacts with untextured stimuli. I could be wrong, though.
Thanks in advance!
MJ
I have not tested all the programs fully under Yosemite to make sure there are no more deadlocks. I would appreciate help on that from the user community ahead of the official 5.0 release, which I'm hoping to get out in the next week or so. That means getting a 5.0a installer out or getting volunteers who don't mind compiling from source to run rvu, rtrace, rcontrib, genBSDF, etc. in -n >1 mode....
Subject: Re: [Radiance-general] strange artifacts in rendering (and Yosemite bug)
Date: August 21, 2015 1:06:40 PM PDT
This is fantastic news! (Roland/Lars, take note...)
I don't recall, is there a concrete test for the fork() thing? I was just in the midst of re-making the Radiance packages (we need to support 32-bit Windows still), but I will *happily* reset the release tag to this commit and start over again, if it means I get to re-enable OpenStudio-Radiance multithreading on Yosemite!
On 8/21/15, 12:59 PM, "Gregory J. Ward" <[email protected]<mailto:[email protected]>> wrote:
Many thanks for the quick turn-around on that, Rob! This mostly applies to Mac OS X 10.10 (Yosemite) users, but anyone who cares to do a before/after timing, that would also be useful.
Date: August 21, 2015 2:47:03 PM PDT
To that end, I just moved the NREL 5.0.a.4 release tag up to Greg's latest
commit, and have posted a fresh Mac installer on there, so now you don't
even have to be able to compile from source to help Greg test this out!
Come and get it:
Release 5.0.a.4 · NREL/Radiance · GitHub
Windows (including 32-bit!) and Linux packages will be re-made and
re-posted to this release page shortly.
Yosemite bug)
On 8/21/15, 12:59 PM, "Gregory J. Ward" >>> <[email protected]<mailto:[email protected]>> wrote:
Sigh. I think in a few more years, anyone who is interested in
scientific computing, rather than business functions or social
networking, is going to be running ChromeOS.
Randolph M. Fritz, Lighting Design and Simulation
+1 206 659-8617 || [email protected]
Come and get it:
Yosemite bug)
On 8/21/15, 12:59 PM, "Gregory J. Ward" >>>> <[email protected]<mailto:[email protected]>> wrote:
It will be interesting to see what ChromeOS develops into. Right now, it's more of a browser manager for accessing online tools, and doesn't have much in the way of compilers or a runtime environment to speak of. Kind of a waste of a laptop, if you ask me....
Date: August 24, 2015 4:53:04 PM PDT
Come and get it:
Yosemite bug)
On 8/21/15, 12:59 PM, "Gregory J. Ward" >>>>> <[email protected]<mailto:[email protected]>> wrote:
Google offers the "Native Client" SDK
(https://developer.chrome.com/native-client\), which supports
compilation and download of code with gcc (wince) and a set of
non-Unix APIs (double wince.) Also, of course, one can just work with
the base Linux on ChromeOS, bypassing the browser completely.
So far as I can see, these tools aren't much used yet; ChromeOS is not
a major development platform. But they are there and at the rate the
major platforms are diverging from general computing applications,
they may be all that will be left in a few years. :frowning:
Come and get it:
Yosemite bug)
On 8/21/15, 12:59 PM, "Gregory J. Ward" >>>>>> <[email protected]<mailto:[email protected]>> wrote:
And I thought app containers were today's next big thing for tomorrow ...
But then, I'm usually behind on those things.
On Wed, Aug 26, 2015 at 11:43 AM, Randolph M. Fritz <[email protected]> wrote:
> -Greg
>> From: "Randolph M. Fritz" <[email protected]>
Yosemite bug)
>>> Cheers,
>>> -Greg
>>>> From: "Guglielmetti, Robert" <[email protected]>
Yosemite bug)
latest
don't
out!
>>>> Come and get it:
>>>> - Rob
the
to get
or
>>>>> Cheers,
>>>>> -Greg
>>>>>> Yosemite bug)
support
>>>>>> On 8/21/15, 12:59 PM, "Gregory J. Ward" > >>>>>> <[email protected]<mailto:[email protected]>> wrote:
>>> _______________________________________________
>>> [email protected]
>> [email protected]
> [email protected]
