src/rt/Version.c does not compile
when I run 'makeall install' against release 5.0 of Radiance (
https://github.com/NREL/Radiance/releases/tag/5.0), file src/rt/Version.c
is automatically generated, with the following contents:
RADIANCE 5.0
Thu Apr 5 13:38:59 UTC 2018
root
6f0749328ec2
Version.c does not compile. It causes the 3 very similar compilation errors
at the bottom of this email. The problem seems to be the dot in '5.0'.
Btw, there is a file called Verscrit.ed which seems to relate to the
content of Version.c, and which contains the following:
1s/^/char VersionID[]="/
2s/^/ lastmod /
3s/^/ by /
4s/^/ on /
1,$j
1s/$/";/
1i
* This file was created automatically during make.
w
q
Is there something sort-term that I can do to prevent this from happening?
If not, is it the case that this is just a minor error that can be ignored
and doesn't prevent Radiance from being correctly installed and ready for
use?
Philip Schwarz
=== ERRORS ===========================================================
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64
-L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o pmaptype.o pmaptype.c
-L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o Version.o Version.c
*Version.c:1:10:* *error: *expected '*=*', '*,*', '*;*', '*asm*' or '
*__attribute__*' before numeric constant
RADIANCE 5.0
*Version.c:4:1:* *error: *invalid suffix "f0749328ec2" on integer constant
6f0749328ec2
make: *** [Version.o] Error 1
-L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o rpmain.o rpmain.c
-DDEVPATH=\"/home/radiance/bin\" -c -o viewbeams.o viewbeams.c
cp ../rt/Version.c .
-DDEVPATH=\"/home/radiance/bin\" -c -o Version.o Version.c
RADIANCE 5.0
6f0749328ec2
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64
-L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o rpiece.o rpiece.c
RADIANCE 5.0
6f0749328ec2
by the way, someone has run into this problem in the past:
Philip
On 5 April 2018 at 16:34, Philip Schwarz < [email protected]> wrote:
https://github.com/NREL/Radiance/releases/tag/5.0\), file src/rt/Version.c
RADIANCE 5.0
root
6f0749328ec2
errors at the bottom of this email. The problem seems to be the dot in
'5.0'.
1s/^/char VersionID="/
2s/^/ lastmod /
3s/^/ by /
4s/^/ on /
1,$j
1s/$/";/
1i
w
q
use?
Philip Schwarz
pmaptype.c
RADIANCE 5.0
6f0749328ec2
-L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/home/radiance/bin\"
RADIANCE 5.0
6f0749328ec2
RADIANCE 5.0
6f0749328ec2
It seems like your Linux (and some others?) don't include the standard "ed" editor or any equivalent. Can you install it?
This script could probably be converted easily enough to 'sed' or Perl, but this is the first I've heard of the problem.
Reporting errors on NREL's github is currently like telling your problems to a congressman, or a black hole. We're looking to fix that, but no one gets notified of those posts at the moment.
Date: April 5, 2018 8:35:45 AM PDT
by the way, someone has run into this problem in the past: Compiling 5.1 on linux · Issue #17 · NREL/Radiance · GitHub
Philip
On 5 April 2018 at 16:34, Philip Schwarz <[email protected]> wrote:
when I run 'makeall install' against release 5.0 of Radiance (https://github.com/NREL/Radiance/releases/tag/5.0\), file src/rt/Version.c is automatically generated, with the following contents:
RADIANCE 5.0
root
6f0749328ec2
Version.c does not compile. It causes the 3 very similar compilation errors at the bottom of this email. The problem seems to be the dot in '5.0'.
Btw, there is a file called Verscrit.ed which seems to relate to the content of Version.c, and which contains the following:
2s/^/ lastmod /
3s/^/ by /
4s/^/ on /
1,j 1s//";/
1i
w
q
If not, is it the case that this is just a minor error that can be ignored and doesn't prevent Radiance from being correctly installed and ready for use?
Philip Schwarz
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o pmaptype.o pmaptype.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o Version.o Version.c
Version.c:1:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before numeric constant
RADIANCE 5.0
Version.c:4:1: error: invalid suffix "f0749328ec2" on integer constant
6f0749328ec2
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o rpmain.o rpmain.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/home/radiance/bin\" -c -o viewbeams.o viewbeams.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/home/radiance/bin\" -c -o Version.o Version.c
RADIANCE 5.0
6f0749328ec2
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o rpiece.o rpiece.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o Version.o Version.c
RADIANCE 5.0
6f0749328ec2
Radiance-dev mailing list
https://www.radiance-online.org/mailman/listinfo/radiance-dev
Incidentally, this is what your Version.c file should look like in the end. If you create this in your src/rt directory, everything should compile from there. Would like to get makeall working right, though:
char VersionID="RADIANCE 5.2a lastmod Fri Feb 16 10:37:53 PST 2018 by gward on photon";
-G
Date: April 5, 2018 8:44:39 AM PDT
Philip
RADIANCE 5.0
root
6f0749328ec2
2s/^/ lastmod /
3s/^/ by /
4s/^/ on /
1,j 1s//";/
1i
w
q
Philip Schwarz
RADIANCE 5.0
6f0749328ec2
RADIANCE 5.0
6f0749328ec2
RADIANCE 5.0
6f0749328ec2
Yes, thanks for supplying the stdout. Greg is right, you need 'ed' as the script is written, easy to sub for some other stream editor. And I am starting to monitor the GitHub issues page more regularly, as people do seem to be using it, but as I and Greg have noted here and elsewhere Philip, it's not really the primary spot for posting these kinds of issues.
    Date:
    by the way, someone has run into this problem in the past: https://github.com/NREL/Radiance/issues/17 <https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FNREL%2FRadiance%2Fissues%2F17&data=02|01|robert.guglielmetti%40nrel.gov|a07c0b91b757429ad53008d59b0c2405|a0f29d7e28cd4f5484427885aee7c080|0|0|636585398817451153&sdata=JEmWYfkHTuDUd7XpyDwTfeAOuA9pd%2FGjFiPeuYdBhaU%3D&reserved=0>
    Philip
    when I run 'makeall install' against release 5.0 of Radiance (https://github.com/NREL/Radiance/releases/tag/5.0 <https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FNREL%2FRadiance%2Freleases%2Ftag%2F5.0&data=02|01|robert.guglielmetti%40nrel.gov|a07c0b91b757429ad53008d59b0c2405|a0f29d7e28cd4f5484427885aee7c080|0|0|636585398817451153&sdata=Z5nWhR8WKAlgVlQZMZRJoxT0LstyicFv4xrnug1iRYw%3D&reserved=0>),
    RADIANCE
    5.0
    Thu Apr 5 13:38:59
    UTC
    2018
    root
    6f0749328ec2
    2s/^/ lastmod /
    3s/^/ by /
    4s/^/ on /
    1,$j
    1s/$/";/
    1i
    w
    q
    Philip Schwarz
     RADIANCE 5.0
     6f0749328ec2
     RADIANCE 5.0
     6f0749328ec2
     RADIANCE 5.0
     6f0749328ec2
Hello Greg,
Yes, about ed, I was getting the following error:
( cat VERSION ; date ; whoami ; hostname ) > Version.c
ed - Version.c < verscript.ed
/bin/sh: ed: command not found
make: *** [Version.c] Error 127
So I installed ed and that error got replaced by a third instance of the
following:
RADIANCE 5.0
6f0749328ec2
I had stopped posting to github, but I saw the same error I was
encountering, and I saw that it had been closed 3 days ago, so I thought it
could be useful to post anyway.
Philip
*Date: *April 5, 2018 8:35:45 AM PDT
Philip
On 5 April 2018 at 16:34, Philip Schwarz <philip.johann.schwarz@ > googlemail.com> wrote:
contents:
RADIANCE 5.0
root
6f0749328ec2
'5.0'.
2s/^/ lastmod /
3s/^/ by /
4s/^/ on /
1,$j
1s/$/";/
1i
w
q
happening?
ready for use?
Philip Schwarz
pmaptype.c
Version.c
RADIANCE 5.0
constant
6f0749328ec2
RADIANCE 5.0
constant
6f0749328ec2
Version.c
RADIANCE 5.0
constant
6f0749328ec2
@Greg
That works.
Great.
Thanks.
Philip
gward on photon";
-G
*Date: *April 5, 2018 8:44:39 AM PDT
Philip
contents:
RADIANCE 5.0
root
6f0749328ec2
'5.0'.
2s/^/ lastmod /
3s/^/ by /
4s/^/ on /
1,$j
1s/$/";/
1i
w
q
happening?
ready for use?
Philip Schwarz
pmaptype.c
Version.c
RADIANCE 5.0
constant
6f0749328ec2
RADIANCE 5.0
constant
6f0749328ec2
Version.c
RADIANCE 5.0
constant
6f0749328ec2
“ex” is a usually a substitute, though it is slightly different from “ed”.
Randolph M. Fritz, Lighting Design and Simulation
+1 206 659-8617 || [email protected] <mailto:[email protected]>
From: Philip Schwarz <[email protected] <mailto:[email protected]>>
Philip
On 5 April 2018 at 16:34, Philip Schwarz <[email protected] <mailto:[email protected]>> wrote:
RADIANCE 5.0
root
6f0749328ec2
2s/^/ lastmod /
3s/^/ by /
4s/^/ on /
1,j 1s//";/
1i
w
q
Philip Schwarz
RADIANCE 5.0
6f0749328ec2
RADIANCE 5.0
6f0749328ec2
RADIANCE 5.0
6f0749328ec2
