I am not sure if this is the correct forum to ask for something like that.. or this forum only deals with radiance software... but i decided to post my question in case that you can help me.
I would like to know what softwares are there, which can found out/compute light sources (and probaply their direction) from hdr image. Are there any other softwares doing this? If they are many, is there anywhere that I can find some information for their differences?
Does Radiance compute light sources from hdr images?
The only software I know doing this is lightgen, a plugin for hdrshop.
Despina
p.s. By the way, is there a known problem with hdrgen (for linux) alignment algorithm? I captured perfectly aligned photos (using remote capturing - connect camera with computer) and using alignement with hdrgen (not use of -a option) results very bad hdr image. Althought when alignement was disable, the result was perfect!
