I'm tearing my hair out here trying to grok mkillum windows vs. sky illumination through the window.
I am trying to visualise the DIRECT sky factor on the floor of a room before and after a new building is put in. The green area is the area that is above 0.2% sky factor before the building and the red area is the area that is above 0.2% sky factor after the new building is put in.
I have tried with and without mkillum:
Skyglow:
Mkillum:
Note that the skyglow one would seem to be much more accurate (basically a big building that covers almost all the window in the top left edge is put in), but the mkillum one has smoother edges.
I guess what I just do not understand after hours of playing with all the rendering and mkillum settings is how to either:
* get rid of the speckling in the skyglow render
or
* make the mkillum render actually accurate (in particular, the green leakage in the top left corner seems wrong)
Can anyone give any suggestions?
Chris
Chris,
This looks like a Rights to Light study, yes? In any case, for the direct sky
factor, whack up ad to whatever gives you a converged value - try a few
in steps of two starting -ad 1024. Turn interpolation off (-aa 0) and, of course,
use -ab 1. If it's RTL, then a uniform sky is used rather than the CIE ovc and
I seem to recall that the window is an aperture without any glazing.
I really wouldn't bother with a source window for something like this.
If the grid was orthogonal, I'd be tempted to supply a grid of points to
rtrace and process the results in my preferred crunching/display software.
-John
Dr. John Mardaljevic
Senior Research Fellow
De Montfort University
The Gateway
Leicester
LE1 9BH, UK
+44 (0) 116 257 7972
+44 (0) 116 257 7981 (fax)
http://www.iesd.dmu.ac.uk/~jm
