Sky and Solar efficacy
When I use Brightdata with measured data , I use this equation;
( sky and solar )radiance= luminance/179
solar luminance is calculated from measured direct normal illuminance.
sky luminance is measured data.
Is this correct methods?
I think efficacy is not always 179.
But it seems to be unified into 179 in the RADIANCE system.
And ,one more question.
When accurate illuminance value in the room is required, should I take both ground plane and ground dome into consideration? Or,ground plane around the model only?
Thank you
Kouichi (?),
But!!it seems to be unified into 179 in the RADIANCE system.
The 179 lm/W value is Radiance's own 'internal' luminous efficacy.
It should not be confused with actual daylighting efficacies
which cover the range 50 to 150 lm/W (these are extremes, typical
values are around 100 to 120 lm/W).
A ground plane will usually be needed for high accuracy work. This is
becuase a (correctly specified) ground glow cannot account for the shading
of the ground plane by the building (see Fig 6.8 in Rendering with Radiance).
No harm in having a ground glow as well as a ground plane.
Both of your questions are addressed (with examples given) in the
newly reprinted Rendering with Radiance book. See earlier threads
for availability.
-John
Dr. John Mardaljevic
Senior Research Fellow
De Montfort University
The Gateway
Leicester
LE1 9BH, UK
+44 (0) 116 257 7972
+44 (0) 116 257 7981 (fax)
in my opinion it is a question of the used spectrum. RADIANCE itself calculates completely within the visible spectrum. So the internal luminous
efficacy of 179 lm/W is from visible to visible spectrum.
The commonly used luminous efficacy is from the full spectrum (as e.g. measured by a pyranometer) to the visible. This efficacy strongly depend on the actual sky state (Blue sky about 90 lm/W, overcast sky about 130 lm/W).
If you use "gendaylit", the perez-sky luminous efficacy model is used to "transfer" full-spectrum data into the visible range and gives good results for the most sky situations.
Jan
John Mardaljevic wrote:
Kouichi (?),
for availability.
-John
Dr. John Mardaljevic Senior Research Fellow
The Gateway
Leicester
LE1 9BH, UK
+44 (0) 116 257 7972 +44 (0) 116 257 7981 (fax)
[email protected] Institute of Energy and Sustainable Development
   o - > \ Jan Wienold
                 Fraunhofer Institute for Solar Energy Systems
                 SOLAR BUILDING DESIGN GROUP - DAYLIGHTING
                 Heidenhofstr. 2 79110 Freiburg
                 GERMANY
          In office: Mo, Tue: 9:00-18:00
     We-Fr: 14:30-18:30
                 Phone: ++49 - (0) 761 - 4588 -5- 133
                 Fax: ++49 - (0) 761 - 4588 -9- 133
                 Email: [email protected]
                                  Internet:
                 http://www.ise.fraunhofer.de
I'm Kouichi.
I'm sorry that the mail was not correctly displayed.
for availability.
Oh, that's great.
I am just going to wait to send the book now!
Kouichi Kobayashi
Tokyo University of Science
