Hi German,
You cannot access two different scenes/octrees from the same process, so
no use in having different ambient files.
Again, it's a limitation in the design of the renderers and their use of
global data structures.
You need to spawn separate processes if you want to render multiple scenes
by calling fork() before you call ray_init().
Sent from my iPad
On Dec 12, 2017, at 8:10 AM, Germán Molina Larrain <[email protected]> > wrote:
Hello Greg,
Well, yes... I want, for example, calculate the illuminance in a set of
sensors using two different skies.... something like:
# first process
oconv scene.rad clear_sky.rad > clear.oct
rtrace -af clear.amb $params clear.oct > clear.txt
# second process
oconv scene.rad overcast.rad > overcast.oct
rtrace -af overcast.amb $params overcast.oct > overcast.txt
The idea is to run both processes simoultaneously, internally in C++... I
am affraid that, when calling setambient() , the first process parameters
are modified.
// Expose the provided options
options->exposeOptions();
// save the parameters
RAYPARAMS rp;
ray_save(&rp);
/* FIRST PROCESS */
// set the ambient file
ambfile = &amb[0];
// set up Radiance
ray_init(&octname[0]);
// RTRACE
for (size_t i = 0; i < nPoints; i++) {
// calculate
rayorigin(&(*rays)[i], PRIMARY, NULL, NULL);
/* SECOND PROCESS... STARTS SLIGHTLY LATER THAN THE FIRST ONE */
ambfile = &amb[0];
// set up Radiance
// RTRACE
// calculate
Will the second ray_init call affect the rayorigin calls in the first
process?
Germán
2017-12-12 12:52 GMT-03:00 Gregory J. Ward <[email protected]>:
Hi Germán,
I don't really understand your question, even with the code snippet.
Multiple processes typically share indirect cached values via the ambient
file (using a locking and update mechanism). Therefore, it makes the most
sense to use the same file name for all processes. This has nothing to do,
however, with the fact that "ambfile" is a global variable.
Multiprocessing in Radiance involves spawning Unix processes via fork(), at
which point even global variables become local to each process. There is
no other mechanism for multiprocessing that is supported by the library, in
part at least to the reliance on global variables. All the memory is
shared on a "copy-on-write" basis, meaning that an OS (like Unix) that can
share memory across processes will do so to the extent possible.
What is it that you really want to do? Do you want to have different
ambient files for different processes? There is nothing to stop you from
doing this -- you just have to reset the ambient file with a call to
setambient() after forking a new process. The disadvantage of course is
that processes will do a lot of duplicate calculation, and you will mostly
negate the benefit of running multiple processes.
*Date: *December 12, 2017 7:29:35 AM PST
Hello Greg and everyone else,
I am working with the raycalls library (src/rt/raycalls.c file) in
Radiance in order to execute lighting simulation internally in a C++
program. I have managed to trace rays (validation remains to be performed),
and I have to say that the library is pretty awesome. What I am doing is:
However, I have one doubt: I would like to run several processes at the
same time, using ambient cache; but the char * ambfile is a global
variable, so I would need to use the same ambient file for all processes
(which is not what I want). How crazy is it to call ray_init with a local
ambient file? Does that just destroy Radiance basic functioning? It already
uses a local octree... that is why I think could be possible. I was going
to try this myself, but I am affraid to mess with the core Radiance code;
so I'd rather ask first.
Germán
Radiance-dev mailing list
https://www.radiance-online.org/mailman/listinfo/radiance-dev
