I have downloaded some nice (and very complex) furniture-geometry from the internet that I like to render in Radiance, but when I create an octree I get the "set overflow in addobject" error. The -r -and -n option do not help.
Is there a way to just skip the 'wrong' geometry (that is causing the error) in oconv ?
Any other options (instead of modelling the furniture myself) ?
-Iebele
have you tried with mesh?
(obj2mesh)
[mailto:[email protected]] On Behalf Of
atelier iebele abel
Sent: 21 November 2005 16:18
Subject: [Radiance-general] set overflow
option do not help.
error) in oconv ?
-Iebele
atelier iebele abel wrote:
What do you mean by "the -r option does not work"? I have had to set -r pretty darned high sometimes, to get big models with fine detail to compile. You get a large octree, and it takes a while to generate, but it works. By "pretty darned high", I am talking about -r as high as one million.
Hey all,
There are a couple of things here. You should probably try to take a look at the geometry and see if there is any extra/duplicate geomery. Doubled up geomery can oftern be a cause for a set overflow like this. You should be able to control a lot with -r.
Guilio's suggestion is also an excellent one. I have found that I can deal with much more complex geometry sets with obj2mesh. And it looks like the file size of the rtm is typically smaller than a corresponding oct file.
# Jack de Valpine
Hi Jack and Rob,
I've tried both your suggestions. Helas, it did not work. I can't spot the error, so I have to re-model the geometry.
Thanks for your support!
Iebele
Jack de Valpine wrote:
Hey all,
Hi Iebele,
The set overflow error includes a hint as to the problem in the form of a surface id. Most likely, the trouble in your geometry is near this surface. If it's not overlapping or collapsed geometry, then it might be a disk that's been converted to hundreds of triangles, all culminating at a single point, which cannot be resolved by oconv because there are more than 511 surfaces in an infinitesimal volume.
If you can identify all the triangles associated with this disk, you should be able to replace it with a single "ring" primitive, or if the edges need to match exactly, with a many-sided face primitive.
Date: November 28, 2005 4:10:44 AM PST
Hi Jack and Rob,
Iebele
Indeed, there are triangulated rings in the geometry. These triangulated rings are easy to identify.
Great! Thanks!
-Iebele
Greg Ward wrote:
Hi Iebele,
Hi Jack and Rob,
Iebele
