Sensor points visualize
  i was wondering
  Is there a way to visualize the selected sensor points from Ecotect in the Radiance output?
  Best, Niya
Hi Niya,
I think you need to be more clear about what you want to visualize? Do you
want to find the sensor in Radiance's files? Is it related to your question
about annual run with Daysim and you want to see hourly values for a single
sensor during the year?
Mostapha
On Wed, Oct 1, 2014 at 7:59 AM, Todor Syarov <[email protected]> wrote:
i was wondering
Radiance output?
Niya
Hi Mostapha,
  It is kind of you correcting me.
  My question concerns only the visual output of the points and their respective values in Radiance image(render). In short: as the image of the interior is, to see the preselected(from ecotect) sensor point with its value for daylight factor.
best, Niya
-------- Оригинално писмо --------
От: Mostapha Sadeghipour [email protected]
Относно: Re: [Radiance-general] Sensor points visualize
До: Radiance general discussion
Изпратено на: Четвъртък, 2014, Октомври 2 14:31:31 EEST
   Hi Niya,
    I think you need to be more clear about what you want to visualize? Do you want to find the sensor in Radiance's files? Is it related to your question about annual run with Daysim and you want to see hourly values for a single sensor during the year?
    Mostapha
On Wed, Oct 1, 2014 at 7:59 AM, Todor Syarov [email protected] > wrote:
       i was wondering
       Niya
var m3_u = (location.protocol==‘https:’?‘https://a.abv.bg/www/delivery/ajs.php’:'http://a.abv.bg/www/delivery/ajs.php’); var m3_r = Math.floor(Math.random()*99999999999); if (!document.MAX_used) document.MAX_used = ‘,’; document.write (" ");
Todor
There is no simple way to visualize the numeric output from Radiance in an
image. If you are only doing it for a small number of renderings the
simplest way is to use something like PowerPoint or Photoshop to add labels
with arrows to the right locations. If you set up a template this can also
be quite fast.
If you want to visualize a larger number of images you have to use some
home made scripts to make this work. You would first calculate the DF
values for your points and then use psign and pcompos to add text at the
right place in the image. You need to be fairly familiar with your
scripting environment (Bash on Linux, CMD or PowerShell on Windows) to get
this to work. If you are a stranger to the command line ask someone to
assist you with this or you won't see daylight soon (pardon the pun).
You can find excellent information on scripting for Radiance on Axel
Jacob's page:
http://www.jaloxa.eu/resources/radiance/documentation/
On Thu, Oct 2, 2014 at 10:08 AM, Todor Syarov <[email protected]> wrote:
Hi Mostapha,
best,
Niya
До: Radiance general discussion <[email protected]>
Hi Niya,
Mostapha
i was wondering
Niya
Thank you for the kind remark on daylighting, Thomas
  I will see how I can manage it. Ouh, I know already Axel´s page -indeed insightful. Just to avoid confusion, my family name is todor syarova
  Kind regards, Niya
От: Thomas Bleicher [email protected]
Изпратено на: Неделя, 2014, Октомври 5 18:13:33 EEST
   Todor
    There is no simple way to visualize the numeric output from Radiance in an image. If you are only doing it for a small number of renderings the simplest way is to use something like PowerPoint or Photoshop to add labels with arrows to the right locations. If you set up a template this can also be quite fast.
    If you want to visualize a larger number of images you have to use some home made scripts to make this work. You would first calculate the DF values for your points and then use psign and pcompos to add text at the right place in the image. You need to be fairly familiar with your scripting environment (Bash on Linux, CMD or PowerShell on Windows) to get this to work. If you are a stranger to the command line ask someone to assist you with this or you won't see daylight soon (pardon the pun).
    You can find excellent information on scripting for Radiance on Axel Jacob's page:
On Thu, Oct 2, 2014 at 10:08 AM, Todor Syarov [email protected] > wrote:
Hi Mostapha,
best,
       Niya
        [email protected] >
           Hi Niya,
            Mostapha
               i was wondering
               Niya
May I suggest:
“opendx”
or as my friend would say nowadays "Paraview" or "MayaVI"
no need of fancy scripting.
take the output -opv, make the photopic average (if R = G = B just take Rx179).
then with the formatted file containing
x y z value
should be very simple in opendx.
for the others I am not sure but I am told it is also simple.
if you need more help let me know, I am happy to provide further help.
ciao
G
Kind regards,
Niya
Todor
Documentation
Hi Mostapha,
best,
Niya
До: Radiance general discussion < [email protected]>
Hi Niya,
Mostapha
i was wondering
Niya
I would also do it with OpenDX. Still, another option all within Radiance:
1) pipe the point locations and the corresponding values into rcalc to get a falsecolor value corresponding to the photopic average and the location as output,
2) use awk to add the string around the numbers to translate this into glow (from falsecolor of photopic average) and sphere (from location, set radius fixed according to density and size of grid or relative to photopic average)
3) render using your favorite raytracer, optionally with all the scene geometry switched to gray (xform -m ...) using all the wonderful view options
Lars.
May I suggest:
"opendx"
x y z value
ciao
G
On 6 Oct 2014, at 14:34, Todor Syarov <[email protected] > <mailto:[email protected]>> wrote:
Ouh, I know already Axel�s page -indeed insightful.
Kind regards,
Niya
??: Thomas Bleicher [email protected] <mailto:[email protected]>
???: Re: [Radiance-general] Sensor points visualize
??: Radiance general discussion <[email protected] <mailto:[email protected]>>
??? ??: ???, 2014, ??? 5 18:13:33 EEST
Todor
Documentation
On Thu, Oct 2, 2014 at 10:08 AM, Todor Syarov <[email protected] >> <javascript: internSendMess('[email protected]')>> wrote:
    Hi Mostapha,
    daylight factor.
    best,
    Niya
    ??: Mostapha Sadeghipour [email protected] <javascript:
    ??? ??: ???, 2014, ??? 2 14:31:31 EEST
    Hi Niya,
    Mostapha
        i was wondering
        Niya
Thank you G., Sounds good!
I am familiar to Maya so this option I need to have a closer look.
best regards, Niya
От: G [email protected]
Изпратено на: Понеделник, 2014, Октомври 6 20:47:40 EEST
  May I suggest:
   “opendx”
   x y z value
   ciao
   G
       Kind regards,
       Niya
От: Thomas Bleicher
        [email protected] >
         Todor
Hi Mostapha,
best,
             Niya
             [email protected] >
                Hi Niya,
                 Mostapha
                    i was wondering
                    Niya
Hello Lars,
  thank you for the break down. I am working now on both options you and G shared with me.Really curious of the outcome. Will post a feedback soon!
  Best, Niya
От: "Lars O. Grobe" [email protected]
Изпратено на: Понеделник, 2014, Октомври 6 21:09:52 EEST
Lars.
     May I suggest:
    “opendx”
    x y z value
    ciao
    G
        Kind regards,
        Niya
От: Thomas Bleicher
         [email protected] >
          Todor
Hi Mostapha,
best,
              Niya
              [email protected] >
                 Hi Niya,
                  Mostapha
                     i was wondering
                     Niya
