Hello everybody,
As it is starting to turn into a new year's tradition, I've just
updated the SCons build system once again.
Good news 1:
With Scons 3.1 (probably since 3.0), despite what the documentation
says, it works very nicely with Python 3.x (3.6 in my case).
After some adaptions from my side, this means that all the Python
code in the Radiance distribution is now compatible with both
Python 2.7 and 3.x.
Good news 2:
Microsoft has fixed their Universal CRT (didn't check in which version).
This means that the line-end-eating bug in pipes is gone, and we can
reliably build Radiance with the current Visual Studio tools again.
I have now completely switched to VS 2017 myself.
Open Issue:
There's a buch of code relating to "out of core octree" building
for Pmap. Most of this compiles fine, except for pmapooc.c, which
is missing some header file includes. Unfortunately, that seems to
be the central cornerstone binding all the others together...
@Roland:
Can you share some insight whether this is supposed to be working,
or still a work in progress that I should ignore for the moment?
Or alternatively, am I doing anything wrong for making it work?
Cheers
-schorsc
Hi Georg! Long time. We are about done with a re-write of the Cmake build system as well, which allows us to do automated build/test/CI on our GitHub mirror of the Radiance CVS repo. Exciting times!
There was some shuffling around of the pmap includes. It’s been building for us on Windows since late summer 2017, I’ll have to look and see what we are doing, unless Roland/Greg know offhand.
On 1/8/18, 6:44 AM, "Georg Mischler" <[email protected]> wrote:
Hello everybody,
Good news 1:
Python 2.7 and 3.x.
Good news 2:
Open Issue:
@Roland:
Cheers
-schorsc
+schorsch.com+ -- lighting design tools -- https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.schorsch.com%2F&data=02|01|robert.guglielmetti%40nrel.gov|1a1e1bdd09444585300608d5569dee6e|a0f29d7e28cd4f5484427885aee7c080|0|0|636510158689605858&sdata=J%2FOY2UqprWww8V0qGdXHRiZ6SurpnVIwzQqHYzc5x1E%3D&reserved=0
Radiance-dev mailing list
https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.radiance-online.org%2Fmailman%2Flistinfo%2Fradiance-dev&data=02|01|robert.guglielmetti%40nrel.gov|1a1e1bdd09444585300608d5569dee6e|a0f29d7e28cd4f5484427885aee7c080|0|0|636510158689605858&sdata=UcMlmf4VOdZ%2FP3anQu%2F%2BJ7BY%2Bts7%2FYZYwdk0vmmbo78%3D&reserved=0
A closer check revealed:
Cmake simply ignores the ooc stuff alltogether
The Rmakefile builds object files from all the oocxxx.c files,
but not for pmapooc.c.
And finally in the sources, I found why:
pmapdata.c #includes pmapooc.c (or alternatively pmapkdt.c), depending
on -DPMAP_OOC.
No provisions to actually set the latter, though.
but that's an easy enough excercise...
After a bit of digging about which files actually need that define,
The SCons build now supports OOC for Pmap, with a configuration option
aptly named - PMAP_OOC.
It is enabled by default on unixoid systems and unavailable on Windows.
The latter is because the code actively refuses to build on Windows.
@Roland
Are you still hibernating?
Are there technically difficult reasons for this, or did you just
not get around to fixing and testing it on Windows yet?
At a quick glance through the code I didn't notice any particularly
platform dependent stuff, but of course I may have missed something.
-schorsch
Am 2018-01-08 16:03, schrieb Guglielmetti, Robert:
Hello everybody,
Good news 1:
Python 2.7 and 3.x.
Good news 2:
Open Issue:
@Roland:
Cheers
-schorsc
Architectural Lighting Design Software
https://www.radiance-online.org/mailman/listinfo/radiance-dev
Hi Schorsch,
Many thanks for working on this.
My memory is that a Windows version of the out-of-core photon-mapping code is on Roland's back-burner, and likely to remain there for the indefinite future. The code relies heavily on memory sharing and the Unix fork() function in its current configuration, and changing that is not an insignificant amount of work.
Date: January 8, 2018 4:15:16 PM PST
on -DPMAP_OOC.
@Roland
-schorsch
Hello everybody,
Good news 1:
Python 2.7 and 3.x.
Good news 2:
Open Issue:
@Roland:
Cheers
-schorsc
