rview opens VIM in VM
Greetings,
Using Radiance on a virtual machine and I am trying to run the scene0 tutorial.
$ rview -vf camera.vp test.oct
After entering this, the camera.vp file opens up in text editor and no image appears on the screen.
I had thought that things were installed proper because it has come this far but I am not for certain.
Your assistance is greatly appreciated. Thank you.
Kevin
"This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution, or the taking of any action in reliance on the contents of this information is strictly prohibited. If you have received this transmission in error, please notify the sender immediately by e-mail and delete the original message."
rview has been renamed to rvu, as several other binaries, because of
naming conflicts with other tools of various, mainly Linux,
distributions. Have a look at the distribution-specific documentation,
which should be located in /usr/shared/doc/radiance-*, there may be more
to read there.
Good luck, Lars.
Kevin.
'rview' in Radiance has been renamed to 'rvu'.
The documentation (mostly old) does not reflect this,
though.
Check that you have an 'rvu' command on your
system and substitute the two whenever you see an
'rview' related to Radiance.
If you don't have 'rvu' you should update your
Radiance version. If that's not possible use the
full path (something like '/usr/local/bin/rview').
On 10 Feb 2009, at 12:49, Kevin Kyte wrote:
Greetings,
$ rview –vf camera.vp test.oct
Kevin
"This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution, or the taking of any action in reliance on the contents of this information is strictly prohibited. If you have received this transmission in error, please notify the sender immediately by e-mail and delete the original message.”
