rtrace for luminance values
I have run into a problem that I think Mehlika Nur Inanici had a couple of year's back.
I am trying to use rtrace to get luminance values on top of a desk surface. The command I'm using is:
cnt 6 12 1 | rcalc -e '$1=51+((72/6)*$1+6);$2=96+((144/12)*$2+6);$3=30' \
-e '$4=0;$5=0;$6=1' | rtrace -h -ov @../options_aa08_ab5 -af b_b_m_2_bare_aa08_ad1024_ab5.amb -e b_b_m_2_bare_illumgrid_task_08_l.out b_b_m.oct \
rcalc -e '$1=179*(.265*$1+.670*$2+.065*$3)' >
b_b_m_2_bare_illumgrid_task_08_l.dat
The values reported by rtrace are in the range of 0.1 to 0.2 candela/meter squared. However, in an image, I am getting values in the range of 1.5 to 2.5 candela/meter squared (which is much more reasonable).
In response to Mehlika's question, Schorsch had mentioned that the header to the pic file would give an exposure value, and that luminance = 179*(.265*R+.670*G+.065*B) / e. But I can't seem to find the exposure.
What am I missing? Where am I not looking?
Thanks.
Hello John. You can use the getinfo command to look at the exposure of an Radiance image. The exposure value is given as EXPOSURE=.... If there is no exposure line, exposure is 1.00 by default.
Hope it helps...
Mehlika
> rcalc -e '$1=179*(.265*$1+.670*$2+.065*$3)' > b_b_m_2_bare_illumgrid_task_08_l.dat
Thanks.
Thanks Mehlika for the explanation. I was using getinfo to find the exposure information, and there was nothing regarding exposure. Can you think of any other reason why this may be happening, and what I might do to remedy this problem?
John
Hope it helps...
Mehlika
> reasonable).
> the exposure.
> Thanks.
John,
Are you sure you are sending the rays in the right direction ?
From the two first lines of your script:
-e '$4=0;$5=0;$6=1' | ....
it seems you are sending rays from a regular grid in a xy plane in the upward direction ($6=1) !
I guess you should ensure your calculation grid is located above your desk (e.g. by setting $3=30.5) and then trace rays downwards ($6=-1). Then rtrace will calculate the luminance values at the rays intersections with your desk plane which is what you expect I think...
Hope this will help you.
Raphaël Compagnon
  it seems you are tracing rays
John
Thank Raphael,
I had always simply taken illuminance values, so I simply thought that taking the -I parameter out would do the trick. It makes much more sense that I would need to send the ray toward the surface I want to evaluate.
John
On May 3, 2004, at 6:01 AM, Raphael Compagnon wrote:
Message: 1
Date: Mon, 03 May 2004 08:57:32 +0200
Subject: Re: [Radiance-general] Re: rtrace for luminance values
John,
Raphaël Compagnon
John
URL: http://radiance-online.org/pipermail/radiance-general/attachments/20040503/75ffd6f8/attachment.html
End of Radiance-general Digest, Vol 3, Issue 2
