Hi List -
I have two questions related to rtcontrib. I'll send two messages for separate discussion threads.
The first is about multi-core runs and a strange error, the second about setting the maximum number of open files on OSX.
Multi-core runs question:
The following command uses 8 processors and successfully generates a bin of 578 .hdr images based on test.oct made of scene geometry, material descriptions and an isotropic sky:
vwrays -ff -vf view.vf -x 800 -y 800 | rtcontrib -n 8 -ab 3 -ad 4000 -as 1000 -dt .05 -ds .1 -dc .17 -lw 9e-19 -e MF:2 -ffc $(vwrays -d -vf view.vf -x 800 -y 800) -f reinhart.cal -b rbin -o bin/%0d.hdr -m sky_glow -w tmp/test.oct
For some reason, one of the bin images is funky (381.hdr in this case) and when I try to do anything with it I get a read error. Example:
pvalue -o -h -H 381.hdr > test.txt
pvalue: read error
I found that I can still view the bad image with ximage, and here the error shows up. The image is shifted 82 pixels to the left, with the clipped pixels placed on the right side of the image.
I re-did the simulation using the exact same command but with just one processor (no -n option) and everything works out fine and dandy. Has anyone else encountered this kind of oddity with multi-core runs and rtcontrib?
Thanks!
Michael
Hi Michael,
Everyone was so busy on your second question, looks like the first one was neglected:
I can't be sure, but most likely you've run into the "bin counting problem." Quoting the rtcontrib man page:
The actual bin number is computed at run time based
on ray direction and surface intersection, as described below. If the
number of bins is known in advance, it should be specified with the -bn
option, and this is critical for output files containing multiple val-
ues per record. A variable or constant name may be given for this
parameter if it has been defined via a previous -f or -e option. Since
bin numbers start from 0, the bin count is always equal to the last bin
plus 1. Set the this value to 0 if the bin count is unknown (the
default).
Not having the -bn option causes trouble in a lot of cases where there isn't always a ray striking the last bin.
Hope this fixes it!
Thanks Greg - that did it. Everything is working smoothly now.
On Jul 20, 2011, at 2:41 PM, Greg Ward wrote:
Hi Michael,
default).
Hope this fixes it!
