got an error message again, this time "missing triangle vertices in mesh_hit" from rtrace (which is called from mkillum), which seams to be from o_mesh.c. I'm using radiance 3.6 at the moment.
The strange about it: I sucessfully rendered the scene before, and now, after changing some setting, I get this error. In fact, the geometry had been changed, but not the object that is reported to cause the problem.
I use oconv with -r 4096 -n 12. Is it possible that this problem occurs as a result of a low -r oconv resolution?
TIA+CU Lars.
Hi Lars,
This is one of those nasty internal errors you should never see, because it means something is wrong with the code. I spent a couple hours just now pouring over it, and I can't figure out how or why it might be happening. I think I need you to send me your scene to try to debug this.
I assume your octree is up-to-date with respect to your scene files, right? I don't see how that could cause this error, but just wanted to be sure.
You might try upgrading to 3.7 just to check that it's not something I fixed before without knowing it.
Date: October 19, 2005 1:57:17 AM PDT
TIA+CU Lars.
