rsensor vs. rtrace
Hello everyone,
I have a noob question - What is the difference between rtrace and rsensor?
and which should be used when simulating real life illuminance sensors for
example for LEED IEQc 8.2 simulations.
I currently used rtrace and recieved results similar to the real life
sensor measurements, but with a result smaller by around 30%. Attached are
my comparisons - Results to the left (study case measurements) should be
multiplied by 10.
Thank you in advance.
https://drive.google.com/file/d/0B3RBjK2uI5SlaV92MTdLVHMzNUkxZWl6NGhWRHZDU19wY0xr/edit?usp=sharing
Bshara Rezik* |* B.Arch
ARCHITECTURE | INTERIOR *| *SUSTAINABLE *|* DESIGN
Address: HaNasi 28A, Apt. 6*,* Haifa, Israel *|* Tel: +972-54-6314584
Website: http://www.bshara-arch.com *|* e-mail: [email protected] *|*
LinkedIn <http://il.linkedin.com/pub/bshara-rezik/20/726/981>
Hi Bshara,
The short answer is that you should use "rtrace –I" (that's a capital 'i') to calculate *horizontal* illuminance for simple workplane calcs, including the basic substantiation calc for LEED. This will give you the cosine-weighted integral of luminous flux incident upon the measurement point, aka illuminance.
Rsensor is a more sophisticated application of rtrace, which computes a sensor signal instead of illuminance. The signal is based on the spatial sensitivity of the sensor in question (or cosine, but most commercial photosensors are nowhere near cosine in their response), and the measurement point would be the actual location of the photosensor. This is how tools like SPOT and DAYSIM-PS do their thing. It's a more accurate means of simulating the actual electric lighting savings, since you're moving the simulation a bit further down the line.
Having said all that, horizontal workplace illuminance (where the "sensor" is on the workplace, looking up) is generally what is calculated. This is certainly true of LEED, and even EnergyPlus and in turn OpenStudio (currently0 calculate wprkplane illuminance and ASSume there is an "ideally commissioned" photosensor that properly responds to that daylight availability and reduces the lighting load. It's not perfect, but it's easier to implement.
One thing I'm also confused about with your poster is that you show views looking kinda southeast, and the plan shows this as well. If you are actually calculating *vertical* eye illuminance, you are getting a useful value for glare calculations, but this is not what LEED is looking for for the basis of satisfying basic daylight levels in the space.
As far as the 30% difference, it's hard to say if that's good agreement or poor, without knowing more about the model, particularly how you re-created the sky conditions for the model.
On 5/6/14, 11:30 AM, "Bshara Rezik" <[email protected]<mailto:[email protected]>> wrote:
Hello everyone,
I have a noob question - What is the difference between rtrace and rsensor? and which should be used when simulating real life illuminance sensors for example for LEED IEQc 8.2 simulations.
I currently used rtrace and recieved results similar to the real life sensor measurements, but with a result smaller by around 30%. Attached are my comparisons - Results to the left (study case measurements) should be multiplied by 10.
Bshara Rezik | B.Arch
ARCHITECTURE | INTERIOR | SUSTAINABLE | DESIGN
Address: HaNasi 28A, Apt. 6, Haifa, Israel | Tel: +972-54-6314584<tel:%2B972-54-6314584>
Website: http://www.bshara-arch.com | e-mail: [email protected]<mailto:[email protected]> | LinkedIn<http://il.linkedin.com/pub/bshara-rezik/20/726/981>
Hi Bshara (& Rob),
For a real-world setting (with trees!), I'd say you were doing pretty good to get within 30%. Is that repeatable for other times/days? If not, it might be a 'lucky hit'. Either way, comparison of simulation with measurements is a valuable exercise I'd recommend to anyone new to Radiance (or any lighting simulation program for that matter).
Cheers
John
John Mardaljevic PhD FSLL
Professor of Building Daylight Modelling
School of Civil & Building Engineering
Loughborough University
Loughborough
Leicestershire
LE11 3TU, UK
Tel: +44 1509 222630 (Direct)
Personal daylighting website:
http://climate-based-daylighting.com
