I read the 3rd workshop 2004 about "Road lightning simulation" by Giulio Antonutto and I am wondering what will happen to the R3 material if I don't have the angle of one degree at the observer position?
Are these the extrapolated data and if yes where do they come from? If not what is meant by that?
Robert,
You need the full dataset.
there is a cie publication with all values
then to see what happens you can always try with retrace and check luminance.
and in case you needed, fill the table with 0 values for unknown data.
I can point you to this link (until it will be available) http://web.mac.com/geotrupes/iWeb/Main%20site/RadBlog/F684499E-33AE-4E8C-959A-85AF81FDBCB5.html
one thing to note is that the plastdata only accounts for direct, otherwise uses the same plastic model.
so the inter reflected component is as usual
G
On 10 Jun 2012, at 20:53, Robert Franke wrote:
