I found this little Python classlet useful when I was running a heap of renderings and thought someone else might, too. Take it as a fragment, suitable for modification.
#!/usr/bin/python
# -*- coding: utf-8 -*-
from datetime import datetime
import sys
import subprocess
RIFFMT ="""# {note}
materials = {matfiles}
scene = {scenefiles}
ZONE = {zone} {bounds}
VARIABILITY = {var}
QUALITY = {qual}
INDIRECT = {ind}
DETAIL = {detail}
AMBFILE = {ambfile}
{views}
class radrif:
def __init__(
self, matfiles, scenefiles,
note = None,
zone = "E", bounds = None,
var = "H", qual = "M", ind = 0, detail = "M",
ambfile = "",
views = ""):
if note is None:
note = datetime.today().ctime()
if zone[0].upper() not in "EI":
raise Exception("Zone must begin with E or I", zone)
if bounds is None:
bounds = self.getbounds(scenefiles)
self.matfiles = matfiles
self.scenefiles = scenefiles
self.note = note
self.zone = zone
self.bounds = bounds
self.var = var
self.qual = qual
self.ind = ind
self.detail = detail
self.ambfile = ambfile
self.views = views
def __str__(self):
return RIFFMT.format(**self.__dict__)
def getbounds(self,scenefiles):
"""Get the bounding box of a model"""
cmd = ['getbbox', '-h'] + scenefiles.split()
PIPE = subprocess.PIPE
getbb = subprocess.Popen(cmd, stdout = PIPE, stderr = PIPE)
(out,err) = getbb.communicate()
if getbb.returncode != 0:
raise Exception(
'Can\'t get bounds of {0}, error {1}: {2}'.format(
self.scenefiles, getbb.returncode, err))
return out
def main():
print str(radrif(sys.argv[1],sys.argv[2]))
if __name__ == "__main__":
main()
Randolph M. Fritz
